Question about Realspace Limble II Glass Computer Desk, 39 3/8in.H x 46in.W x 21 1/2in.D, Black
Can I get replacement parts for limbless I I desk?
Need slide for key board tray
I need the glass top of the slide out tray of my zentra collection computer desk
fixya doesnt sell products check with manufacturer or place that cuts glass
Dec 23, 2017 | The Office Equipment & Supplies
I need replacement hardware for an antique drop front desk
Restoration Hardware. High quality. Many old fashioned antique items, door knobs, etc. Whatever you need. Home store in Long Beach, just order online.
Oct 17, 2016 | Miscellaneous
Kodak slide tray mechanism
The Carousel 140 Trays were manufactured as "one-timers" - - - that means (unlike the Ektagraphic 80 Slide Tray), there are no adjustments, no replacement parts, and are not designed for re-assembly.... I am sorry to have to tell you that. My recommendation would be to buy a replacement tray (don't worry - - they are cheap) from a dealer who still has 140 trays (try www.vinevalleyimaging.com )
Good Luck!! Jim
Feb 08, 2014 | Kodak Office Equipment & Supplies
How can I tell if an old table I inherited is a writing table or a drafting table?
These two tables usually look very similar. If the drafting table was at a flat setting with the height set at regular desk height (maybe 74 cm) then it looks just like a writing table. The way to tell if it's a drafting table is if there is an edge on one of the sides. The edge was used to stop things from sliding off the table when the table was at an angle and it would sometimes hold writing tools.
Jan 03, 2013 | Furniture
How to take apart a metal tray slide? Like the one in desks?
Check if the keyboard tray slide rail has any screws...?
If not, i guess that means total disassembly of the desk and ofc...rebuilding back! :)
Nov 16, 2017 | Computers & Internet
My cd rom desk will not open! How can I fix this?
When you say CD-ROM doesn't open. Then i'd say check 2 ways..
Turn on the computer and let be in BIOS screen then try to open tray, if its open there is no problem in H/W part, else the issue is with CD-ROM.
If its not opening after OS boots, then you need to really try be deleting the UPPER FILTERS & LOWER FILTERS keys in registry settings.
Jan 12, 2010 | Dell Latitude D800 Notebook
Under desk sliding tray won't slide
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Dave
Nov 21, 2008 | Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD...
Tv is (bowing) rainbow effect, now turns on for second then shuts off
I had the same problem. The issue may be the same although I am not sure the powering off is related to the convergence issue. This is what I did: 1. Order the STK392-570 convergence IC and heat sink thermal transfer paste( I silicone based)..(make sure it is a reputable company so you don't risk getting bad components, I got them from an electronics supplier in MD) 2. UNPLUG YOUR TV AND ALL COMPONENTS!!!! 3. Remove the back cover and black plastic cover. (retain all parts) 4. remove the retaining bolts and screws on the black plastic tray (they are on the sides verticle mounted and front center as you are looking down on the tray.) This allows the tray to slide out like a keyboard on a computer desk. DONT PULL IT OUT YET!!!! 5. Just above the boards there is a shade board that slides out. Carefully pull it out. 6. You will have to unplug all cables ON THE BOARDS except for the RED ONES ON THE FAR RIGHT and provide tension relief for the cables by carefully unraveling them. The cables are marked on the connector and match to the markings on the board (I.E. KM, all connectors are marked with a two letter designation) Just disconnect the cables from all the boards and nothing elese. 7. Now carefully slide the tray about half way so you can see the contents of the entire center board. This is the board you need. Look in the back center of the board. There is a really large heat sink. The ICs are on the back side of this heat sink. They are held in place by a retaining bar that sandwiches the heat sink to the ICs. 8. There are some connectors on three sides of the board that are flat and white. CAREFULLY ....AND I MEAN CAREFULLY pull the left (as you are looking at board) ones up and disconnect from the center board. The ones on the right (I think they disconnect from the right board). 9. Unscrew the board from the plastic tray. There are a lot of them around the perimeter and center as well as the ones that hold the heat sink onto the board ( they also hold the board onto the tray.) You have to remove the "sandwich bar" (refer to 7)in order to get at the screws that hold the heat sink to board. (you have to unscrew them. 10. There is a box shaped cover on the left front part of this board that is screwed onto board and is also part of the retension to the plastic board, remove it to. (always remember to be careful when tugging, unscrewing, ect as it could result in breaking somthing) 11. There are black plastic tabs to the rear of the board. Unhook those and CAREFULLY lift and pivot the board forward and then up and out. 12. Now comes the easy part. You may have to pry the heat sink from the ICs carefully because of heat sink paste. Clean off the heat sink (dont use cleaner, just wipe the old grease off) 13. Use a good soldering iron (PACE, regulated, good desoldering iron) The temp just needs to be high enough to heat solder. 14. MAKE SURE YOU REMOVE THE CARD THAT WE TALKED ABOUT EARLIER that is in the front left of the board. You dont want it to break. Turn the board over so the chips are facing down. Take the desoldering tool and put it over the pins and in a circular motion until it heats the solder and push the sucker button. Do this to all of them that relate to the ICs. DONT KEEP IT TOO LONG ON BOARD. once you have done that to all pins, gentely tug on the chip wiggling it out. (carefully!!!!!) if you feel resistance desolder a little more. Make sure your desolder device is giving enough suction. 15. Now solder them back on and make sure you dont create any cold solder joints. This would be bad!!!! 16. Apply a decent amount of thermal heat transfer (grease, goo, ect) Make sure you do this or bad things will happen. You need this stuff. You can get it at radio shack. 17. Now put it back together and hurray you are done... Hope this helps... GOOD LUCK DJ
Mar 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Picture is bowed at the top and bottom of the screen.
I had the same problem. I had to have the convergence chips replaced. Cost me about $380.
Nov 13, 2006 | Mitsubishi WT-46809 46" Rear Projection...
CONVERGENCE PROBLEM... I THINK
This kind of problem ussually starts by being intermitant and the first thing to try is to resolder all the pins in the convergence IC's , they create a lot of heat and are mounted on heat sinks for that reason but after a while the solder cracks and it does not make a good conection,down the road they migh need to be replaced but for now lets hope they only need resoldered as well as many other overheated areas in the chassis.Let us know if you need more information.
Nov 06, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Realspace Limble II Glass Computer Desk, 39 3/8in.H x 46in.W x 21 1/2in.D, Black Logo
183 people viewed this question
Top Realspace Furniture Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Realspace Furniture Expert? Answer questions, earn points and help others
