Used remote to select "AV" but nothing.
If not already done connect rca cable with red white and yellow rca plugs to the rear of the dvd player,then plug the other end of the cable to the tv rca input of which there should be two sets 1 and 2
take note which set you use,now set the tv to match the video input to the number 1 or 2 .
using the remote select source then scroll up or down to av 1 or 2
don't forget to switch on the dvd player.
unles the dvd player is faulty you should be able to find the pic
good luck
Len...
SOURCE: Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
SOURCE: I downloaded a movie in
hi,
just install K-lite Codec to avoid such codec problems
you can download it here .
this makes you to play all video formats in all players installed in your system.
regards,
cseian
