Not connected to a computer just making copies from the printer
SOURCE: Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
SOURCE: Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
SOURCE: error masege "part end life" at Epson CX4600
Go to the Epson website and download the reset program and run it.
They will have a disclaimer telling you that the ink pad MUST be replaced by a trained tech, or the ink will overflow and short out electrical parts. I have had my printer for over 5 years and most of my ink goes into the ink pad as I dont use it much and most of the time at least one of the print heads is clogged, my pad was no where near overflowing. I soaked up as much as I could with tissues.
If you move the catridges to the left and look down you will see the ink pad. Use rubber gloves, it is very messy
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The print told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
SOURCE: E-02 Error "Replace Ink Cartridge"
After you have installed the new ink, take it out again, and check that the hole has been pierced. Then, shake the ink by giving it a quick suck until some ink comes out, and then replace the cartridge into the printer. This worked for us anyway. Good luck!
SOURCE: epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
