Question about Hunter Designer's Choice 5-Switchblades Lg Room ceiling fan by Fan
How can I get a new remote for Designer's Choice ceiling fan FCC ID M8CRL 103?
Contacts in remote no longer work.
Fan Fair Of Boca
    Genius:
  • Hunter Master
  • 1,617 Answers
Call 1-888-830-1326 with model # of FAN.
Posted on Sep 15, 2014
2 Related Answers
Anonymous
SOURCE: I have a Designer's Choice remote ceiling fan. I
With mine, I turn off the full power and back on and it starts beeping and and press any button on the remote and it finds it and does a couple confirmation beeps.
Posted on Sep 05, 2009
Anonymous
  • 57 Answers
SOURCE: Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Posted on Apr 09, 2012
1helpful
My remote stopprd working! I replaced the batteries and it still does not work! FCC ID. M8CRL. 103
if you replaced the batteries id attempt to use a universal remote... if that does not work the tv remote receiver may be bad
Jul 05, 2016 • Dryers
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
1helpful
2answers
How to use remote on ceiling fan id m8crl 103
Press the light button and bottom green button at the same time the lights dimming feature will work!
3answers
Remote control, changed battery, still nothing
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Hunter Designer's Choice 5-Switchblades Lg Room ceiling fan by Fan Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Mike
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
