Question about Mitsubishi WS-55819 55" Rear Projection Television
How do I fix Dark edges on Mitsubishi 55" projection tv?
The tv has dark edges when picture is on
5 Related Answers
Anonymous
  • 80 Answers
SOURCE: Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Posted on Oct 16, 2008
Anonymous
SOURCE: picture getting dark on my 70" mitsubishi projection
I FINALLY got the problem fixed!!! Gee I feel stupid. I called a great local TV repair guy and he came out and fixed it for next to nothing. The stupid part is that all he had to do was take apart the TV's front fascia and clean the mirrors and things inside....it was FILTHY!!! Then the TV was like new again. It looks so good I wanted to kiss him. He advised that you really should be cleaning that about once a year or so to prevent this problem. Also, I live in Nevada with HIGH dust so that doesn't help either.
Posted on Dec 05, 2008
jose martinez
  • 159 Answers
SOURCE: Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Posted on Apr 17, 2009
Anonymous
  • 11 Answers
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Posted on Jul 07, 2009
Kenneth Lee Sr.
  • 597 Answers
SOURCE: Hi: I have a Mitsubishi WD 52527 projection TV.
go to menu...correct brightness
Posted on May 20, 2010
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blackening around edges of Philips 55PL 55" LCD
Check any magnet or some speaker are near ur tv . Off it for 1 hrs , re on it & check
Dec 23, 2017 | Philips 55PL9523 55 in. LCD Television
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Nov 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
