All doors lock,but the interior lights stay on & the alarm wont arm.this happens intermittently
SOURCE: Interior lights stay on and no power windows
It’s a wire that is part of the wiring in the driver side door.
If you wish to fix yourself, (disconnect battery and follow all safety measures per your manufacturer’s recommendations) there is a black rubber gusset (accordion style tube) that contains the wiring harness to the door. On the door side of the tube you will find tabs on the top and bottom you can squeeze together to pull back and reveal the harness connector that is also located closest to the door.
Disconnect the harness and pull back though a hole located in the area directly under the interior fuse box. This might not be the easiest task, so when you pull back the rubber tube, check for any broken wires. You can lightly pull on each wire to see if one is loose if you are not able to visually locate the wire in question.
Repair the wire using the best method available to you and reverse the removal. Return the harness back though the door, plug in the harness, and snap the tube back into place. I found this after a good deal of troubleshooting and had to fix the same wire in a different section about 2 years later. This should be recalled as I have fixed 2 friends with the same problem.
Remember also to be safe and if you need to replace any wires, contact your dealer for details on the repair. This is doable, just take your time and plan to be in the area working for at least 30 minutes to an hour if you are good at repairs.
Good Luck...
SOURCE: I have a 2004 Jeep Grand Cherokee limited edition
I had same problem it is a ground wire broken in the harness rubber boot between dthe driver door. Peel back the rubber that protects wires and you will find broken ground wire(black) add a piece of wire solder and wrap with electrical tape put rubber boot back into door everything should work.
SOURCE: 2002 jeep power windows and door locks stopped
SOUNDS LIKE YOU HAVE BROKEN WIRES BETWEEN DRIVER'S DOOR AND BODY AT A PILLAR..PULL RUBBER BOOT FROM BODY AND DOOR AND INSPECT WIRING HERE
SOURCE: Power door locks and windows dont work, interior
Had the same issue - as gche37 noted the black ground wire is normally the issue.
Pull the boot back on the wire bundle in the door and you will probably see the broken wire. I then spliced a wire to the one running into the door. I pulled the black wire into the car, spliced to that and it worked (works) fine. Took about 15 minutes. I splices with a 12 ga braided wire
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
Battery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
