Question about Tally Line Matrix T6050 Printer
HOW TO SAVE T6050 PRINTER CONFIGURATION
HOW TO CHANGE THE PAPER SIZE AND SAVE THE PRINTER CONFIGURATION
3 Related Answers
Anonymous
  • 6 Answers
SOURCE: printer problem T6050 ( Tally )
this problem is occure due to logic card,pfmotor pfbelt,or the control pannel switch defective. upadhyay girish
Posted on Sep 29, 2007
arielsolanoy
  • 13 Answers
SOURCE: i want to set paper
fAQWfthjshbgfhbghb
Posted on May 21, 2011
tariqalitari
SOURCE: thiruvallmy tally t6050 shows paper
phase problem facing t6050.
Posted on Jul 06, 2011
My Printer Wehn i print some thing say (Remove paper Standard Tray)
Probably because the printer driver is set up to print from the photo tray instead of the paper feeder as default.
Try making the necessary adjustments regarding paper source and paper size in you printer driver configuration and save the changes as default .
Hope this Solves your problem
Jan 07, 2014 | Office Equipment & Supplies
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
I bought canon printer MF4150 from Singapore. The problem is when i print or photo copy A4 or legal size after 1 printer it errors and said load proper size @ MP tray
The printer may have a setup for a region which will change the paper size. Also the paper tray may need to have the paper size adjusted on it physically. Save the paper size in the preferences to A4.
Nov 17, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
Mar 20, 2008 | HP LaserJet 4050 Printer
Printer problem T6050 ( Tally )
This problem is occure due to Logic Card Problem or Paper feed motor Problem. Bhavin - India
Apr 06, 2007 | Tally Line Matrix T6050 Printer
Tally Line Matrix T6050 Printer Logo
129 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Zaid Anarwala
Zaid Anarwala
CheckitRight
CheckitRight
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
