The plugs sparks bbut the generated will not start
SOURCE: Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
SOURCE: Coleman6250 Generator PM0545007 - Won't start/run.
Most gasoline engines need three basic things to run: proper air/fuel mixture, sufficient compression, and a properly timed spark. Check the easiest, cheapest things first, then check the "Gee, I forgot to turn on the gas" kind of things next, then work your way onwards from there.
Compression can be guesstimated with the proverbial thumb-over-the-empty-spark-plug-hole routine as you turn it over casually to check compression. If it doesn't blow your thumb out of position, you could have a hole in the piston (overheating response) or a stuck or damaged intake or exhaust valve.
Check for fuel flow by carefully disconnecting the fuel line to the carburetor and letting some run into a tin can (no styrofoam coffee cups, please). It should dribble freely. If not, you have to back-track the line and find out where the blockage is.
Spark is one that sounds like you've already tested (spark plug out of the cylinder head, hooked up and laying on the metal engine as you turn it over?) so check timing. You will probably need a manual for this test, although a good estimate is that the plug should fire just a wee bit before Top Dead Center position of the piston. Like I said, a manual comes in handy here.
From what you've mentioned, though, I'd start trouble-shooting at the fuel flow part first.
Good luck,
GRB
SOURCE: My 5250 watt Power Back generator will not start,
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
