Communication error listed in print queue have tried power off/on reset and reloading software. When the printer is switched on it does all the usual things and the print page on the computer is all normal press print and the awaiting print box is shown the job then stalls and communication error is shown in the print manager box. I think it may be gone to god could you pls advise.
Okay I would first go to epson's site and get the latest drivers for the device. The problem could be if your using the driver given to you by the manufacturer that the drivers could be useless due to a random windows update. Verify that you have the latest drivers and then attempt to connect the device again. If you continue to get the communication error then the device is likely faulty and needs to be replaced.
SOURCE: BLACK INK NOT PRINTING
Hi Hmmg,
This is a clear indication that some thing is gone wrong in your printer's circuit. Please get it checked by an authorized service engineer.
Regards.
Nat
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
