Question about Electronic Arts Sim City 4: Deluxe Edition for Windows
I need a activation code for sims 4 please????????????????????????????????????????????????????
Activation code for sims 4
Posted by Elissia Duszynski on
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
Tip
Unlocking code for samsung j600/j700 mobiles
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700/j600 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
on Feb 02, 2010 | Cell Phones
I need a sim unlock code for a galaxy s5 active please
You would need to contact your service provider to obtain this
Aug 04, 2016 | Samsung Galaxy S5 Active G870a 16GB AT&T...
Yar sim card rejected
There may be various reasons for it.
1) Your SIM card might be damaged. Check inserting the SIM card in any other active unlocked phone.
2) The SIM port on the cell phone might be damaged. Check inserting any other active SIM card to your phone.
3) The cell phone might be network restricted. Try inserting any other network's active SIM card to it. If the device reject that too, then you need to unlock the phone. You can unlock a Nokia C1-01 safer and easier using unlock code. You can get the accurate unlock code for a Nokia C1-01 from TheUnlockArena.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia C1-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C1-01.
3 - Compose #pw+CODE+1#.
4 - The Nokia C1-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C1-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C1-01
Oct 05, 2014 | Nokia C101
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
I have locked my new micromax Q75 mobile phone. How can i unlock immediately? Please help
If the SIM card has been inserted in the phone, and the related PIN code protection is activated, you need to enter the 4-8 digit password to unlock. Warning: If you enter three wrong PIN codes in a row, the SIM card will be locked and you need to enter the PUK code to unlock. Both the PIN code and PUK code are provided by the network operator.
Sep 21, 2010 | Health & Beauty
My china mobile IMEI:-35269500557980 and when sim is putting it was say invalid sim pls tell solution sir
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Pin code request when turning phone on
hey everyone.
i have read a couple of threads i have found on the internet and i have tested this on my samsung sgh-c450 locked to telstra. no computer is needed (or cable). i hope this helps anyone with a samsung. WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Aant. Harry----- punt 4 is vervallen ivm met het verwijderen van de emei-code.
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
Aantekening Harry: Om de codes in te voeren moet je een keer op de rode toets (naast C) drukken, zodat je in het beginscherm komt. Dan kun je codes intoetsen. Dus geen codes intoetsen als je in het keuzemenu zit.
a)
If Network Lock is "Active", put in the following code:
Message should be "Network Lock has been personalised" or similar.
Then:
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
Message should be "SP Lock has been personalised" or similar.
Then:
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
"a)" is the common one that usually is the only one need to be done but if other locks are active, i think its best to disable them now while you have the chance.
Now you have unlocked your phone!
Tested on:
SGH-C450
Please test this!
Thank You.
Sep 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Electronic Arts Sim City 4: Deluxe Edition for Windows Logo
860 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
Andrew Armstrong
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Bill Boyd
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
