My kid locked her self out of her tablet yall tell me it needs a factory reset anyone no how to do that? its a dl700d digiland 7" tablet
Here is a step by step I found :)
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process
Posted on Mar 24, 2015
I have tried that repeadly and its not wqrkin insnt ther a way to rest it with pc
Now I have 1 Chinese line after selecting 6th option. It won't go any further. I tried pressing the power button and vol. down again, but nothing!
Actually, when I press vol. down, it brings me back to the multiple options
Ah-ha! I chose the 6th option that WAS NOT HIGHLIGHTED and that started the reset process.
Why is the not working for me it doesn't even go to the root screen it goes straight to the screen locked screen
Posted on Feb 06, 2016
taking the battery out will do it
Posted on May 06, 2012
SOURCE: how to reset curio 7 tablet to factory settings
long press volume + and then power for 15 seconds when boot
Posted on Jan 11, 2013
SOURCE: How to reset Pandigital 7 in. Planet Tablet to
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Posted on Oct 17, 2011
SOURCE: how to factory reset a iview suprapad 7" 1gb tablet
press FACTORY RESET button in settings
Posted on May 07, 2014
SOURCE: UNABLE TO LOG ON TO SLY ELECTRONICS 7" 4GB TABLET
Hold down the power button and the volume up button after shutting it off.
You might need to flash new firmware.
Posted on Jan 15, 2014
