Question about Broderbund Calendar Creator 12 for PC
I was using an older version (like 3) of calendar creator with windows 98 but now I have upgraded to windows 7 and had to get calendar creator deluxe v12.1. I do an event calendar monthly and when there is more than one event for a day it double spaces between the events. How can I change the line spacing in the text box?
As far as I can tell ther is no way to change the line spacing on the Calender Creator Delux edition. However, there is a work around. You can find out how here: Margins Line Spacing.
Hope this helps!
Posted on Feb 05, 2015
SOURCE: suddenly, when I go to
What is the duration of the event that you are specifying? You are sure you are restricting it to just one day? Please give me a little more info here and I can help you out!
Thanks
Posted on Sep 09, 2010
Jan 19, 2014 | Broderbund Calendar Creator Deluxe 10 Full...
on Mar 22, 2010 | Computers & Internet
Oct 02, 2012 | Broderbund Calendar Creator 8 Full Version...
The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
1. Start-->Control Panel-->Add/Remove Programs.
2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
3. Follow the panel wizard and reboot your PC when it finished.
In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
1. Free download Perfect Uninstaller form its official website.
2. Install Perfect Uninstaller on your computer
3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
Under Creative Commons License: Attribution
Feb 03, 2011 | Broderbund Calendar Creator 12 for PC
Dec 29, 2010 | Broderbund Calendar Creator 12 for PC
Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing the compatibility settings for the program, either manually or by using the Program Compatibility troubleshooter.
Go to the Windows website to watch the video. (1:26)
If changing the settings doesn't fix the problem, go to the program manufacturer's website to see if there is an update for the program.
Warning
Do not use the Program Compatibility troubleshooter on older antivirus programs, disk utilities, or other system programs because it might cause data loss or create a security risk.
Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
To change compatibility settings manually for a program, right-click the program icon, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 Ă— 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Change settings for all users
Lets you choose settings that will apply to all users on this computer.
Dec 18, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
Nov 14, 2009 | Computers & Internet
May 29, 2008 | Microsoft Windows 98 for PC
Mar 26, 2008 | Computers & Internet
Dec 11, 2007 | NEC PGA370 SIS620 ATX Motherboard...
Sep 11, 2013 | Broderbund Calendar Creator 12 for PC
266 people viewed this question
