I am trying to determine a seven letter word made from the above letters for an image in the Drawsomething Iphone game. The picture is a red rectangle with a white arrow pointing to the right.
SOURCE: seeing red outlines of letters/images and bent picture.
You need new convergence ICs replace both of them. they are located on the D board
SOURCE: Top left and bottom right images/letters distorted.
I can fix it for $325? 213 880 1795
It was a convergence problem, both chips goes bad bad also look for bad resistors around the circuit? This is not an easy repair for non skilled person? You need to realign it after replacing the chips? Don't be cheap pay someone to do it right?
SOURCE: phillips convergence proplem . red arrow will
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
SOURCE: Color shadowing on white lettering
This is called convergence.
If the TV has auto convergence or 'Flash Focus', run it. All projection TVs have customer controls for minor adjustment. Give it a go with the menu or the remote convergence controls.
If not, this is a common adjustment made by a technician on a house call.
If the error is really big, say the colours are curved or you can see clear separate letters and things, you will need the convergence repaired. Get a quote - Usually about $300- $600 in home service.
Testimonial: "You called it correctly. It had an adjustment on the menu for the convergence. Thank you."
