Question about Marantz SR7005 Receiver
My Marantz SR7005 is connected via HDMI to a pc media player with internal DVD player. The Marantz is set to Dolby PL2 movie surround mode (Great). However whenever I play a DVD which is 5.1 surrou
5.1 surround speakers = OK Other devices connected (eg: Sat box) via HDMI do not have this issue. PC media centre is Windows 7. Issue only occurring last few weeks! was ok before!
5 Related Answers
Anonymous
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
Anonymous
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
jason
  • 905 Answers
SOURCE: No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Posted on Oct 06, 2008
Anonymous
  • 1637 Answers
SOURCE: marantz sr 4000 is connected to satellite dish, cd
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
PLEASE SEE THESE SOLUTIONS
1. Take a look at how your non working set of speakers is routed and follow the same routing for the working set of speakers.
2. Check to ensure that both channels A AND B are selected to play when TV FUNCTION IS ENABLED
3. IF your still experiencing problems, please respond with answers to these two simple questions
4 when is the last time both sets of speakers worked for the TV FUNCTION?
5. WHAT WAS the last thing you did before both sets stopped working?
Posted on Jan 11, 2011
gopakumarg43
  • 76785 Answers
SOURCE: Recently purchased Marantz SR7005, all
Hello
Go its user manaul page [76 & 77]. You can understand what Audyssey is. Make it OFF. Proceedings are there one these pages. OK.
Posted on Jan 08, 2012
2answers
My Denon AVRX3100 works fine with my Dish Network TV. The Panasonic DVD player (attached to either DVD or Blueray inputs) only has partial sound. The movie background music plays but not the voices.
Your denon amp amp does not match and work well
in some players for instance "Samsung" no pictures
and sound via HDMI input. Only replacing players
to another brand such as LG can fix the problem.
1helpful
Keep losing Internet connection
Sounds like an internal board problem , call smasung they can send a tech right to your home to check it out !
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
1helpful
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
1helpful
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
1helpful
2answers
here is more info
Marantz SR8500
instead of HDMI.
Out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
Marantz SR7005 Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
