When there is a message and the handset is picked up, it beeps, but the message waiting light does not flash.
I assume you have pap2t admin password....
login to admin
click on Line 1 tab.
change "VMWI Serv:" to yes.
save
click on advance view.
click on USER 1 tab
goto bottom.
With vmwi being on, you will get a periodic ring splash to let you know you have VM. You can adjust it here. I have mine set to 0.2 seconds as I like getting a whole house ring to let me know there is new VM, so I don't have to remember to look at the phone/light. Some set this to 0.0 seconds in order to get rid of the ring splash. I also set "Ring On No New VM:" to yes because I have an old caller-id box that needs a ring splash AFTER retrieving VM in order to clear its message waiting light. Newer stuff generally doesn't need this.
save.
You would need to turn off provisioning or your changes will go back to provisioned settings every hour. After you are sure you like the new settings, you can send a ticket to get the settings changed in the provisioned file at VT.
SOURCE: Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
SOURCE: My phone will just go dead with no notice.
This sounds like you need to replace the battery in both hand sets. You can also get the user manual here if you have lost the one that came with your phone: http://service.us.panasonic.com/OPERMANPDF/KXTGA520.PDF
