Somehow, the ringer on my Apple 4s got turned off. How do I turn it off or on? The message on the screen prompts to either accept or decline but no ring.
There's a button above the volume up key that you can toggle to switch between mute and sound. By the way, if you want to change and customize your iPhone ringtone, you can follow the detailed steps in this tutorial: How to Add Ringtones to iPhone?
On the left side of the iPhone screen you have a switch that works for ring on and ring off
SOURCE: Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
SOURCE: Stuck on silent mode and cannot get the ringer to ring
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
SOURCE: I somehow turned off the
Most modern phones have 2 buttons for volume control. This typically will change ringer volume (including vibrate / mute).
If that doesn't work, post your model number and we can give more exact answers.
SOURCE: My ringer is not working on my I phone 4S phone I
There are a few issues that could cause your iPhone to be silent when it should be ringing.
First, on the side of your iPhone there is a switch just above the volume buttons. If you can see an orange strip in this switch, toggle it upward (toward you when the display is facing you).
If this does not resolve your issue, go to the Settings app and tap on the Sounds section. Make sure the Ringer and Alerts volume slider is all the way to the right. Also, tap on Ringtone and then any of the Ringtones in the list. If you cannot hear the ringtone when it is tapped, it is most likely an issue with either the software or the speaker.
If you are able to hear other sounds from the speaker on your iPhone, but not the ringtone, it is either a software issue or the mute switch (the side switch from the earlier step) has stopped responding. Try hard restarting your iPhone by holding the power button on the top of it until you see the Apple logo. If the issue persists, back up your iPhone to iCloud or your computer and visit an Apple Store. They will most likely need to restore (erase, hence the need for a backup) your iPhone to factory settings. If that does not fix the issue, then it is a hardware problem. All software repairs at Apple Stores are free, but hardware repairs may cost money if your iPhone is out of warranty.
Instructions on how to backup and restore your iPhone, if necessary: http://support.apple.com/kb/HT1766?viewlocale=en_US&locale=en_US
I hope this helps. If you have any questions about the instructions above, let me know and I'll do my best to help.
