Uniden D1680 Cordless Phone Logo
A
Anonymous Posted on Sep 12, 2014
Answering system gives wrong date and time. How do i change this. Phone handset displays correct date and time
3 Related Answers
A
Anonymous
  • Posted on Dec 26, 2007
SOURCE: Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
Anonymous
  • 7191 Answers
  • Posted on May 14, 2010
SOURCE: DECT 6.0 Cordless Phone with Digital Answering System and Caller ID: looking for manual on dect2188-5 5 handsets 1 bas...
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Anonymous
  • 8197 Answers
  • Posted on May 01, 2011
SOURCE: how do I change the
May I get the model # to help you change the time
How do I change (set) correct date and time?
You can download the user manual from here, and it will help you set the date and time: http://www.tutodoc.com/download/uniden-d1785-3t-owners-manual.pdf
How do I change time on my uniden phone
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580om.pdf
Setting the Day & Time
To change the time shown in the display, follow the steps listed below.
If you do not set the clock on your answering system, your messages on the
answering system may not have the correct time and day stamp.
Press MENU/SELECT.
Move the cursor to Day & Time and press MENU/SELECT.
Use and to select the day of the week, and press MENU/
SELECT.
Note: The day of the week does not appear on the handset display.
Use the number keypad (0 through 9) to enter the hour and minutes.
Use and to select AM or PM, and press MENU/SELECT. You hear a confirmation tone
How do I set the date and time on the answering machine of my my Panasonic cordless phone model kxtg5632. I have a lot of power outages and every time I have one the date and time falls off the answering...
5 8 GHz Expandable Digital Cordless Answering System with Two Handsets
Possible issue if you have Caller ID:
Why does the date and time change automatically after I have programmed the date and time on my phone?
If you are subscribed to Caller ID from your phone company, the unit's date and time setting will be automatically adjusted when caller information is received. If you do not wish for this feature to work, press [MENU] [#] [2] [2] [6] on the handset, then press [0] to select "Manual" and press [SAVE]
ftp://ftp.panasonic.com/telephone/om/kx-tg5631_en_om.pdf
Page 21 - setting date and time in manual at link above.
9helpful
2answers
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
1helpful
2answers
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
3helpful
2answers
IN 120 base keeps flashing CL
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
3helpful
2answers
Time and date
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
1helpful
2answers
Time and date
I'm almost positive there's nothing wrong with your phone "ssandra". You set the day/time/year etc. on the base (answering machine) separately from the handset . . . you press a series of buttons. I've done it several times, but now after a move I can't remember how you do it, and I can't find the instructions I had. That's actually why I was on this forum (looking for the instructions). Since you posted your question last year, this probably can't help you now. But I thought I'd answer anyway . . .
3helpful
"CL" blinking on the display of my answering machine
CL is the clock. Set the time and date on the lower right hand side of answering machine.
Answering system
It first sounds as if the handset isn't charged properly. Check the battery status first. The manufacture advises to charge the system for approx. 7 hours before any use occurs. Second, make sure that the registration took, when programming the phone originally. I would de-register the handset by: 1 {MENU} i {0}{0}{2} 2 {3}{3}{5} i {OK} 3 Select the handset you want to cancel by pressing the desired handset number ({1} ? {4}). Then re-register by: 1 Handset: {MENU} i {0}{0}{1} 2 Base unit: KX-TG6021/KX-TG6022/ KX-TG6023 Press and hold {LOCATOR} until the IN USE indicator flashes. KX-TG6051/KX-TG6052/ KX-TG6053/KX-TG6054 Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes. LAfter the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until a beep sounds. 4 {OFF} Third, make sure that the display on the handset does not show "SP-Phone" in the display, if it does press the phone icon button. Fourth, Do you currently have voicemail from your phone service provider? If so, the answering machine will not answer. Make sure that the answering machine portion is turned on. Do this by: Press {ANSWER ON} to turn on/off the answering system. When the answering system is turned on, the ANSWER ON indicator lights. When the answering system is turned off, the ANSWER ON indicator turns off. If there are any further questions or comments, please post here. Please rate this solution through fix-it. Thank you
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
