Question about EK Success 5" -TWEEZER BEE
Can I take tweezers in hand luggage
Tweezers to trim eyebrows
Mister Danger
  • EK Success Master
  • 5,631 Answers
NO. YOU CAN'T. IT WILL BE DETECTED AND CONFISCATED. Actually, you don't need to have tweezers in your hand luggage.
Posted on Apr 05, 2017
Sandra
    Problem Solver:
  • 14 Answers
It depends where you are travelling, and how hot the security are feeling. I have had them confiscated on a flight to Ireland, but got through on flights to Europe. I'd take them, but don't take your best Tweezerman ones!
Posted on Sep 12, 2014
How to replace 2010 ford explorer mini fuse
Most vehicles come with a small fuse remover placed in the fuse panel cover.....Normally it is red,white ,or yellow..To remove and replace a fuse ..,make sure the component that the fuse controls is off...If it is a simple fuse just lightly tug it side to side and it should come right out..If it is a huge type relay disconnect negative battery cable for safety..They make die electric lube you can use to lightly dab on the new fuse to make it slide in and out easier...I have used everything such as small needle nosed plyers to pocket screwdrivers in some situations...But you have to be careful not to damage anything especially other fuses surrounding the bad one....The BEST thing I have found is a good strong set of eyebrow tweezers...They make all kinds of tweezers however a cheap pair isn't good enough...they make a small sized professional tweezer which is very strong...Also .You could go to the parts store and probably find a cheap fuse puller..Tweezers are my favorite..
Feb 22, 2015 | 2010 Ford Explorer
What to do when the needle is stuck down through the fabric and will no release
be careful, release needle clamp and slowly rock the hand wheel. use tweezers or small pliers to hold needle and gently twist/pull as the wheel is rocked. The needle will loosen and come out with patience, use as little force as possible
Feb 09, 2014 | Janome Hello Kitty 15822 Heavy-duty...
I have a unibrow ie my eyebrows dont really separate in the middle. What can I do about it?
Tweezers are a good way of shaping and getting eyebrows under control, but if you have a uni-brow then you will need a more long term solution otherwise you could end up plucking your eyebrows every day!
Look into laser treatments or electrolysis for a more long lasting solution.
Feb 18, 2013 | Health & Beauty
I am a man and have recently got into the idea of hair removal for myself. Are tweezers an effective way to remove my hair? I am scared about the idea of waxing.
Tweezers are good for small areas that need hair removal such as; eyebrows, nose, knuckles and around the nipple area. But this would be much too time consuming and painful to do on large areas of your skin.
How do you remove hair from your eyebrows with tweezers?
It's good that you're asking because if you want to pluck your own eyebrows with tweezers, you really need to do your research first so that your don't end up looking really silly.
Take a look at this feature on Oprah's website. It gives a really detailed tutorial about plucking your own eyebrows and what shape to choose etc;
http://www.mako.co.il/mako-vod-mako/documentary-s1/VOD-343177f0c077e21006.htm
Radio won't eject tape
tape is probably caught in the reels, you might have to force it out of the deck, i forced mine out with my eyebrow tweezers, the tape was obviously ruined cause it ripped, but better the tape than the deck...
Aug 17, 2012 | 1997 Buick LeSabre
My Whirlpool LHW0050PQ front load washer's tub is making a clicking noise when turning. It almost sounds as if there was a metal part stuck between the tub and the inside of the machine. Is ther
Have you lost any underwires in any bras? Would be my first check, as years ago I had a similar sound & it turned out to be part of a broken underwire from my bra, I manage with a bright torch & a pair of tweezers to locate the offending object by slowly turning the drum with my hand & the teasing the metal through one of the drum holes & retrieved it, I wasn't ever going to pluck my eyebrows with the tweezers again but hey, they're cheaper than washing machines!!
I hope this helps, let me know if I can help any further...
Feb 28, 2018 | Whirlpool LHW0050PQ Front Load Washer
How to remove memory card for s230
How about a pair of eyebrow tweezers or something similar?
Jul 01, 2010 | Nikon COOLPIX S230 Digital Camera
My Mom order this product and never used it. She
This interchangeable tweezers device (pat. pending) will do wonders for the way you feel about yourself. When you follow these simple instructions, Emjoi Beauty Forever will rid you of unwanted hair for the long haul! You can decide whether to use the coil-tweezers or the gold-plated tweezers based on these broad criteria:
The coil-tweezers enable you to clean out at a time a multiple number of unwanted hair (most notably, at the bikini line and some facial hair).
The gold-plated tweezers are intended to remove individual unwanted hair (like those on the eyebrow or on the breasts).
To use Emjoi Beauty Forever efficiently, please read carefully the enclosed Instruction Manual and pay a special attention to the following:
Clasp the unwanted hair with the Emjoi Beauty Forever's coil tweezers or gold-plated tweezers. At the same time, press the handle button for 15-20 seconds. The indicator light on the inside panel (near the adapter outlet) lights more brightly and will remain so during the application.
Slide the hair out gently in the direction it grows. If the hair doesn't slide out easily (some hair is more stubborn than other), gently tweeze it out. Even the coarsest hair is removed with a lasting effect by the Emjoi Beauty Forever's unique epilation treatment.
These helpful tips will assure extra-effective epilation!
The shorter the hair, the better the results. Preferably, hair should be no longer than 2-3 mm (1/10 in.)
Your skin should be completely clean before treatment.
To make skin more supple and relaxed, wash with warm water and gently massage.
Make sure no radios, TVs, or cordless phones are operating during treatment since they may interfere with RF transmission.
If a hair remains after 3-4 consecutive treatments, tweeze it. It has been sufficiently treated. There are some hair roots that need more treatments, particularly those that are dark and thick, or near throat, chin, lips, thighs and bikini lines.
Mar 08, 2010 | Emjoi Beauty Forever Epilator
EK Success 5" -TWEEZER BEE Logo
275 people viewed this question
Top EK Success Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you an EK Success Toy Expert? Answer questions, earn points and help others
