Looking to find what ohm speaker to use with my Motorola HS-544 amp .
Here you go: http://techpreservation.dyndns.org/schematics/Motorola.htm
Being that old, most likely the speakers are probably 8ohm good luck finding those. You can use 4ohm but you may hear some distortion at higher volume levels.
SOURCE: amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
