How do I get inside to check out the motor & main power switch?
SOURCE: Canister works, vacuum doesnt
There could be a break in the electric from the machine to the hose - or from the hose to the wand - or from the wand to the Power Nozzle - or it could be the motor is bad. Wiggle the cord at the Hose with it running- then go to the Wand - then to the Power Nozzle. You may find a break in the wires anywhere along the line. unplug the Vacuum: If you have a meter check to see if the reset is working - and last check to see if the motor will work removed from the Nozzle. Ralph
SOURCE: Electrolux Advantage Series canister vacuum
There is an area on the back of the tank where you will see lines, put your thumb there and pull the top half of the tank towards yourself. That should open the machine so you can replace your after filter.
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
SOURCE: I have an older Electrolux canister vacuum - model
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
