F 150 2006 model power window on driver side will not roll up
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
SOURCE: power windows isuzu rodeo 1999
Cable must of disconnected need to take door cover off and reconnect...
SOURCE: Right-side power windows will not roll down
well check window switch on driver side first does it roll down from that side / does it roll down from passenger side/ next if not do you hear the motor if yes its the switch in driver door that is bad / if you don here the motor then its the regulator/motor that needs replacing/ Please rate my response thank you very much
SOURCE: Divers window won't roll up my Camry
No won't be fuse. My guess is there is something faulty with the main controller. You could probably verify this by trying the switch on right rear passenger door. If it works there then the problem is at the main controller in the driver door. Could be a loose wire or the switch itself is broken.
