Question about Samsung Cell Phones
How do I unlock my straight talk phone if I dont know the password?
Somehow my phone got locked and it won't take any of my passwords.
Angela Dill
    New Friend:
    Problem Solver:
  • 6 Answers
Today, I had the same if not similar problem, so I contacted the carrier. They directed me to a blog geekbuying.com/index.php/2013/12/03/how-to-erase-your-lock-screen-password-or pattern.on your android-device/#.Up20100bju4. Although there are several methods to unlocking a lock phone, as I was trying method 2, where ADB command to help you erase the password, if you still don't know what is ADB, and how to use it, here is the instructions: http//www.howtogeek.com/125769/
If you understand the ADB very well, then, the command is here: adb shell rm /data/system/gesture.key
this is for erasing the password;
adb shell rm /data/system/password.key
this is for erasing the pattern.
both methods are all based you have open the USB Debug. How about you forget to open that? If you don't open the USB debug and there is only two ways to erase the password:
1- flash the firmware again for you device; (because different phone has different firmware update instructions just google the information you need)
2- wipe the data and cache. (instruction is here http://smallbusiness.chron.com/wipe-data-cache-android-316
As I began downloaded some of the requested files I stumbled across unlock your android device without USB Debug on, or a google account and still retain your files, using emergency calls or sim swap. I decided to utilized this one as I was not sure if my DeBug was on or off and to my surprise it worked.
Method 1 - The Screen lock bypass
Will work on all android devices running android 2.3 x or below no matter whether rooted or not.
How to use: Extract the gingerbread lock bypass file anywhere on your PC, install drivers for your phone using pdanet. Connect your device to the pc using USB cable, go to the extracted folder, run the Double_Click_Me.bat file and enter 1 to continue in the command window. Try unlocking your device now. The screen lock will be bypassed.
Method 2 - This will work on all android devices 4.0
How to use - Install drivers for your phone, you can search online using your phone model, connect your device to the pc using USB cable, go to the extracted folder. Run the Double_Click_Me.bat file and enter 1 to continue in the command window. Try unlocking your device now. Any password/pin/gestures that had been currently stopping you from having access to you device have been cleared.
I most definitely cannot take the credit as I don't know all of the websites I was on, but I made copies to follow the instructions and on the last two that seem to have worked for me and I hope it works for you their is a man name Andrew Miracle, android download and on top it had Tecmie Info Center. I am giving you word for word as I use their quotes because it differently worked for me.
My passion is to help people and as I stumbled across this website fixya and I hope I have been successful with the help of others to help others.
Posted on Sep 13, 2014
5 Related Answers
haaamid
SOURCE: Unlock Nokia N95 8GB
plz give nokia n95 master cod
Posted on Dec 01, 2008
Anonymous
SOURCE: kid locked phone somehow now dont know code to
code should be last 4 digits of your phone number
Posted on Feb 22, 2009
Anonymous
SOURCE: Dont know the user name or password for google to unlock the phone
Remove the battery on the phone and then turn it back on while holding the home and power button at the same time. It should bring you to the bootloader screen. Press Alt+L and then Alt+W to wipe the phone. When you reboot the phone now, you can log into your gmail account, but only if you are a T-Mobile customer with the G1 data plan. T-Mobile doesn't track IMEI's so it doesn't matter if it was reported lost or stolen
Posted on Jul 06, 2009
Anonymous
  • 4 Answers
SOURCE: Privacy Locks
Try this reset code:
*2767*3855#
Posted on Aug 14, 2009
Anonymous
  • 12 Answers
SOURCE: the factory password to lock or unlock my phone samsung sgh-t329
The default Samsung factory password is 00000000
Posted on Oct 03, 2009
How can I unlock my screen lock when I forgot my password on a Android lgl34c straight talk tracfone
Call the cell phone service provider and prove that you own thef phone and are the account holder and they can unlock it for you.
Aug 08, 2014 • Cell Phones
1helpful
How to unlock a password
How do I unlock a Samsung Centura Straight Talk phone that has a password and has locked me out.
How to unlock straight talk phone I have lost the unlock password?
Have you forgotten the Security code for your mobile that is locked with Straight talk network? What is your mobile model? I suggest you to try default codes like 00000 or 12345.If it does not work out you can use master reset generated code from Unlocking4free.com and reset the mobile.Here they provide master reset for Nokia (Basic) and Alcatel mobile models
Unlock my straight talk
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 03, 2012 • Cell Phones
3helpful
NEC DT700 phone lock
just lift the handset and put password. 0000 is default password.
Forgot username and password for my phones google account
Give your phone to the company's service center, they would solve your problem.
4helpful
2answers
Hi my sony ericsson xperia saying too many pattern attempts ask me to put username(email) and password i dont have any username and password please help thanks
Hi there.
When you try to unlock the phone more than 5 times it locks the phone but only for 30 seconds and you can try again, this is right from Sony's site, you will have to call them for the only way I know is to either try to remove everything from the phone, Sim, Battery and leave it for 10 minutes and try it, if not then you can try Sony's default unlock code 0000 . other than that see if you can get into the phone menu somehow to turn it off or do a Factory Reset.
Let me know if you need further assistance.
Thank you!
12helpful
5answers
2helpful
Dont know phone lock password please help
POST YOUR IMEI AND MODEL NAME
MORE VISIT http://eazy-unlock.webs.com/
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Michael Thomas
Michael Thomas
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
