Question about Samsung HCL4715W 47" Rear Projection Television
My samsung hcl4715w has a 3d look too it it was made in 2001
Read Chapter 3 about adjusting the convergence controls. These are to do with the alignment of the colours. It will help you fix the 3D look.
TVs
Posted on Sep 14, 2014
SOURCE: HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Posted on Aug 28, 2007
SOURCE: Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Posted on Apr 20, 2008
SOURCE: How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Posted on Apr 25, 2008
SOURCE: SAMSUNG HCL4715W
the HCL473W, HCP4752 are basically the same set same features. The HCL models like the HCP are rear projection. Unfortunately Samsung no longer manufactures the rear projection CRT models they are only available in the DLP rear projection with the closest comparable model currently available for a new replacement would be the HL50A65 which is a 50 Inch 1080P suggested retail 1299.00 If I can help you further please let me know. Also new replacement chassis are available for the HCL4715W.
Posted on Jul 02, 2008
SOURCE: tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Posted on Jan 03, 2009
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
Jun 22, 2010 | Samsung HCL4715W 47" Rear Projection...
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Jan 07, 2009 | Samsung HCL4715W 47" Rear Projection...
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Dec 01, 2008 | Samsung HCL4715W 47" Rear Projection...
Jul 02, 2008 | Samsung HCL4715W 47" Rear Projection...
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Feb 17, 2007 | Samsung HCL4715W 47" Rear Projection...
78 people viewed this question
