Car Audio & Video Logo
A
Anonymous Posted on Sep 11, 2014
How do i connect the 70-5700 to a 2000 lincoln town car?
THERE ARE THREE CONNECTORS ON THE TOWN CAR RADIO.DO I CONNECT THE LEFT OVER WIRES FROM THE CD PLAYER TO THE OTHER TWO CONNECTORS ON THE TOWN CAR?
Don Malinowski
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Sep 17, 2014
Don Malinowski
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
11921
Points
43
Not all wires from the CD Player need to be connected to the town car, but you should know what the wires in the town car do. A wiring diagram or stereo adapter from any place that sells after-market radios should be a lot of help.
1 Related Answer
Anonymous
  • 174 Answers
  • Posted on Jun 05, 2009
SOURCE: Car Stereo will not turn on
Voltage Regulator which is situated a the rear of the stereo. FixMyRadio .net
2002 town car, need to find mating connector
Is it inline connector? Can you bypass connector? Splice like color wires to each other? I can't see anything from here, bypassing connector, just a thought. Use your best judgement. good luck.
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
2007 Toyota Camry When I put disk in the CD player after about 30 seconds of it flashing saying reading disk it then shows an ERROR 1!?? Any help??? Thks
It can be dirty or faulty disk,but if that's not the case the problem relates to cd player lens.Its not reading the disk.The inside lens which reads and detects the cd is either got dirty or its faulty and unit has to be replaced.-------So whether is dirty lens or faulty that can be confirmed once the unit is inspected.Try running lens cleaning cd in your cd player unit and see if that is helping.========For more help i suggest refer the help links mentioned below:------
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
My Ford Ka radio/ 6000 CD RDS EON doesn't work.
It can be the problem with cd player mechanism,on many cases just removing the cd player system out of dash and servicing the unit helps to take care of such problems.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
1helpful
2002 saturn lw 300 radio quits
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
When my head lights comes on in my 1997 lincoln town car the radio do a constant scan, just keeps scanning i have changed the light switch
The headlight wiring and radio wiring is getting in contact and causing the short.Both the grounds needs to be checked.Because when headlight is off,the radio work's fine.As soon as the headlights are turned on,the radio goes in scan mode.Its clear indication of radio and headlight wiring issue.The wiring's are getting in contact with ant metal surface or both the radio and headlight wire are coming in contact,where they should not.I suggest you to check the headlight and radio wiring diagrams for your lincoln town car.Here is the direct link.Click the link below :---Check out all the 3 links one by one.Radio wiring diagram for 1997 LincolnTown Car?http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
----------------Lincoln Town Car Radio stereo wiring?
---------Headlight wiring diagram for 1997 Lincoln Town Car?http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
----------This will help.Thanks.
I have a 1995 lincoln town car signature series that im trying to put a aftermarket cd player in i was tole that i have to cut the wires from the amp in the back and run them to the cd player is there a...
Before you cut the wires try Walmart and Auto Zone and look for a Conversion kit. They run about $5 and give you a connector that will fit the factory connection and allow you to add the aftermarket device. I know for a fact they have them for aftermarket radios and I'm pretty sure they have them for a separate CD player if that is what you actually have.
Wiring a new radio in a 1991 lincoln town car
assuming you are looking for a color chart - here it is...
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
