My gauges dont work properly
SOURCE: Tachometer, fuel gauge, temp gauge, speedometer
Check the fuse for the gauges, either around the dash, or under the hood.
SOURCE: I have a 2004 Chevy
Bad Stepper motors....the motors in your cluster are very weak... there is an upgraded motor x 25-168...cost 175.00 parts and labor to replace all of them. Ive repaired a lot of clusters with this very problem
SOURCE: The gas gauge on my 2002 chevy venture is not
Hi:
Your tank sending unit is bad. Unfortunately, it is part of the fuel pump assembly, and the part costs around $400, give or take. plus installation labor. It is an all too common problem on GM vehicles, as I have had to change it on my last 2 GMs. If you do an internet search you will find plenty of others in the same boat!
SOURCE: 2004 Dodge Ram 1500 5.7L at start up check gauge
Sounds like the oil pressure sending unit needs replaced.
