Question about Worldwide 1991 Ford F150 Pickup 5.8L Alternator - 75 Amps
What do codes 32 75 12 22 mean on check engine light
Codes in key on engine off position
Posted by james allan on
  • james allan
    james allan Sep 12, 2014
    Thank you. I'm an older guy and not real computer savie.i don't understand why i couldn,t just see a list of those codes on line without giving up my info. Was ready to walk to the library and look for the book. thanks for saving me the walk.
  • Brad Brown Sep 13, 2014
    MY pleasure
  • Worldwide Master
  • 18,439 Answers
12 idle air speed motor control
22 MAP sensor bad
32 EGR valve not responding
75 Brake light switch shorted.
Posted on Sep 12, 2014
What is the hr3732 check engine light code mean on my 2007 dodge caliber r/t
the code should start with a p not hr, i think you just read how many hours the engine has run for. just turn key on and off 3 times third time leave it in run position this will display the codes. dont touch the trip button.
Mar 12, 2013 | Cars & Trucks
Engine turns over but will not start.
Hi there:
When the light comes on, one or more diagnostic trouble codes (DTC) are stored in the engine control module. These DTCs remain even if the light goes out. To address a Check Engine Light problem, the DTCs are retrieved and the appropriate troubleshooting information is followed in order to determine the problem.
Just scanned the computer and send us code number find it.
Hope helps.
Mar 14, 2012 | 1995 Dodge Ram 2500
My car wont stay idling
Lets start with figuring out why the check engine light is on. You can get a blinkout of the the code by switching you key to the on and off position three times quickly and leaving it in the on position on the final time (note, do not take the key so far that it tries to start the engine). So start with the key in, and engine off, quickly turn the key to on, then off, then on, then off, then on and leave it there. Now watch your check engine light. It will blink out any codes that may be stored. The blinking will have breaks between each code and each code is a two digit number. For instance, blink short pause, blink blink, long pause, blink, blink, blink, pause, blink, blink, would be codes 12 and 32. I believe the final code is 55 and just simply means "end of codes". That should at least tell you if its an issue the ECU has detected. You can do a quick google search to find out what each code it spits out means. As for a guess as to why it isn't idling...I've seen everything from a failing fuel pump (inadequate pressure), to a clogged EGR valve cause this. Could be quite a few things unfortunately. Good luck!
Feb 25, 2012 | 1995 Chrysler LeBaron
Check engine light came on for about an hour then went back off..Tried to get it to come back on but couldn't ..Today the car would not start,engine just turned over let it sit for about 10 minutes and it...
To many things that can cause the issue your having. Drive to Auto Zone and they can scan your PT Cruiser free of charge and can give you the recommended solution to address any DTC codes that is retrieved.
Thank you for using fixya and post abck with your DTC codes.
Aug 24, 2010 | 2005 Chrysler PT Cruiser
Engine cutting out at 2500 rpm on my 2004 pt cruser and engine light is on ,problem comes and goes ,this is very frustrating on the highway
You can check the engine code by puttuing the key in the ignition...in rapid recesion turn the key to the on position and back to the off position 4 time ending in the on posistion. Wright the code down and search i on google or at www.autozone.com. Correct the error.
Jul 26, 2010 | 2004 Chrysler PT Cruiser
My 2001 dodge stratus engine lights keeps coming on
With the car off, turn the key to the ON position, but do not start the engine. Then turn the key back to the off position.
Repeat this three times. The electronic odometer will display the engine trouble codes which are 4-digit numbers that help diagnose engine problems. When those problems are resolved, the light should go out.
To find out what the 4-digit codes mean, check here.
http://www.ptcruizer.com/computer-codes.html
May 07, 2010 | 2001 Dodge Stratus
Check engine light came on and stayed on
Put the Key into the Ignition and turn from OFF to ON (not START) Position, which is right before Start and do this three (3) times. On the third time leave the Key in the ON (not Start) Position.
If you have a didgital Odometer look there for codes (example P 0123). There may be several so wait until it reads "donE". Record these Codes.
If you do not have anything reading in the Odometer window: Look immediately at the Check Engine Light and count the number of times the Check Engine Light blinks (on and off). There are two (2) digit blinks, then a pause followed by pause followed by more blinks. Record the number of blinks. The last set should be five (5) blinks followed by five (5) blinks.
Get back with me on what the blink counts were. (example 18, 23, 55).
Let me know if this helped, and provide me with additional information I requested. Contact me at FixYa.com using the comment section of tyour original Posted Question.
Feb 16, 2010 | 1995 Jeep Grand Cherokee
Maintenance light blinks several times when I turn my 1999 Acura TL on. It goes off after about 30 seconds should I be concerned.
this may mean its time for an oil change it's the cars way of saying it's time for a scheduled maintenance.
Turn the key off and push and hold the select button. Keep holding while you turn the key to the on position (not the start position) keep holding for about 15 seconds then turn the key back off . next turn the key back to on position the light should only come on once. now you can start the car
Jan 06, 2010 | 1999 Acura TL
Check enggine
Do a self test. Turn key to on position and back to off position 3 times. a series of flashes will commence from the "check engine" light. The first set of flashes is the 1st digit of the code, then there will be a pause, then a 2nd set of flashes, This will be the 2nd digit of the code. For example, 3 flashes, pause, 7 flashes, means code 37. Check what the code means in a Haynes auto repair manual. This will tell you what the engine light on your car means.
Jun 12, 2008 | 1998 Jeep Cherokee
Worldwide 1991 Ford F150 Pickup 5.8L Alternator - 75 Amps Logo
65 people viewed this question
Top Worldwide Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
