I've tried to press home and volume key and open button at the same time. it doesen't work :/
Have you entered too many times your unlock code on your phone?
Yes means,you can't unfreeze through pressing home and volume key and open button at the same time.Getting unfreeze code is one of the best way to remove your freeze.If you need cheap unfreeze code visit
Mobile-Unlocker.com
SOURCE: volume button
if u r referring to the in call volume....then u can increase it while ur talking on the phone only, with the same button through which u set the key tone volume...........
i hope this helps u......if it does, then pls don't forget to rate the answer....thanks
SOURCE: unable to put phone in silent in times of need - samsung j700
press <Menu> → Settings →
Phone settings → Phone profiles.
You should see different profiles such as Normal, Outdoor, meeting, etc. Choose the one you want to use. You can change the rings for each of these profiles by selecting the one you want and choosing options/edit.
SOURCE: hello! I'm having problems during a phone call
Did you happen to update to iOS 5? Because since the update. Mine has been the same way. The volume is very low. and sometimes even the speaker isn't too loud either unless I'm playing music.
If you did not update to iOS 5. Then your speaker might be blocked and easily cleaned with a cotton swab, or the speaker is just old and going out.
SOURCE: constant black screen on my galaxy S GTI9000
Solution-no but pretend that you are trying to get the phone right for the first time. Take the manual in your hand and do what you have to do to change the screen colour.
I do not know the prosydure by heart soI leave it to you.
Kolbrun
SOURCE: How do I set voicemail ringtone for Samsumg Galaxy S3
Click on phone icon, click menu > call settings > scroll down to voicemail settings select ringtone select the ringtone you want click OK
