Question about Sony PlayStation Portable (PSP) Console
Frozen PSP The psp says "Please wait" on the screen and won't do anything
Posted by Calvinator on
  • 5 more comments
  • harleybikes Dec 07, 2007
    screen says please wait and will not turn off.
  • Anonymous Dec 26, 2007
    WAS PLAYING MADDEN O8 PAUSED IT AND SHUT IT OFF. lATER WHEN I TURNED IT ON THE PAUSE MENU TO PLAY IT AGAIN IT FROZE AND I COULDN'T DO ANYTHING SO I PRESSED THE HOME BUTTON AND PRESSED YES TO EXIT. IT SAID PLEASE WAIT AND IT HAS BEEN FROZEN THEIR FOR ALL DAY.
  • trezz8 Dec 27, 2007
    it says disk can not be read
  • CraizieGirl Jan 01, 2008
    My son's PSP screen is frozen with 'Please Wait' on it.....and, it won't even turn off. It's not even a week old. Now what?? It just doesn't seem right to take out the battery to solve this problem. Any suggestions are appreciated!! :)
  • King JJ May 25, 2008
    My PSP is frozen on the start up screen
  • Anonymous Jun 09, 2008
    My son has the same exact problem - what is the solution to this????
    Tried unplugging from charger - but the power button does not turn off to restart.
  • Anonymous Nov 26, 2008
    the psp says "please wait" and cannot do anything
Anonymous
  • 3 Answers
Mine did that, i took the battery out and cleaned some dust off the inside of it, it worked after that
Posted on Nov 10, 2007
  • lyndarose Feb 13, 2011
    thanks alot; you saved the day!
Anonymous
  • 3 Answers
Take out the battery and put it back in.If this does not solve the problem then all u need to do is to just let the psp battery drain till its finished by keeping it on.then recharge.
Posted on Oct 21, 2008
a7878
  • 502 Answers
There may be a physical issue with your motherboard or UMD drive. If you want to fix it yourself, You can get the part at psp Repair and there is a guide that shows you how to put in the part at psp Repair Guide.
Posted on Apr 14, 2011
Anonymous
Need new one or clean the lazer
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
PSP screen shows"Please wait..." for
Has the psp had a fall if so check to make sure the umd drive cable is still connected to the mother board maybe it slipped out. thus telllin you please wait to load umd if not write back an be specific
Dec 15, 2010 | Video Game Consoles & Games
Cant off the psp go and still on screen is please wait..cant go to the menu
Greetings,
It seems like your Psp Go has gotten stuck on that screen. The only valid way to fix this is to either:
  • Wait for the Psp to Die. Just let is sit and it will run out of power eventually.
  • Pull the battery out of the Psp which will cut the power. Then place battery back in and turn on.
Thank you for using FixYa! =) If I helped, please give me a rating.
Dec 10, 2010 | Sony PSP (Piano Black)
Psp wont switch off just says on screen please wait fully charged just cant do anything
Try removing the rechargeable battery completely from the device and then reinstall it.
Dec 30, 2009 | Sony PlayStation Portable (PSP) Console
PSP Won' turn on
wait, so when you turn it on, the wave shows or nothing shows? and to turn it back off you have to hold it for like 30 seconds.
Sep 23, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP USB connection- screen reads please wait
there might be somthing wrong with the hard drive or with the usb
Mar 31, 2009 | Sony PlayStation Portable (PSP) Console
My psp is froze up and says please wait. i can,t
boy open the part were the batery is and open it then take out the batery and play with the buttons without the batery and put it back in *******
Mar 22, 2009 | Sony PlayStation Portable (PSP) Console
Update problem with psp
SOMETIMES TAKE THE BATTARY OUT AND PUTTING BACK IN AGAIN WORKS.
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
377 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
