Question about Music
How can I attach a 1/4 inch cord to my ca-110 tonebank to record the nusic played through a tascam dp-008 pocket studio
There are no 1/4 inch receptors on the casio ca-110 keyboard. Is there at all a solution
Jay Plesset
  • 2,942 Answers
There is likely a 3mm connector. Get an adaptor from what you have to the 1/4" size. They're readily available and pretty cheap.
Posted on Sep 11, 2014
2 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: My casio ct670 ToneBank keyboard isn't making much sound
Check that you don't have old batteries in the unit. Also that the auto power down is not activated.
If using a power adapter make sure it is the RIGHT one, both in polarity and current rating.
Posted on Sep 22, 2009
Testimonial: "Sorta helpful. How do I check for auto power down activation? Thanks for responding so soon. I'm not using batteries and used the original ac adapter."
James Riley
  • 37 Answers
SOURCE: what kind of adapter do i use for my keyboard Casio ca-110
if you don't want to wait, you can go to radio shack and get a universal adapter for a bit more, but it should work no problem.
http://www.amazon.com/HQRP-Adapter-compatible-Keyboards-Replacement/dp/B004TXDL3C
Posted on May 26, 2012
How do I factory reset Casio lk 110 keyboard?
Unplug while unit is on. Then press and hold power button for about a minute. Replug back in see if that does trick. If not call company for a hidden code if available.
Aug 31, 2017 | Casio Music
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
What kind of adapter do i use for my keyboard Casio ca-110
May 26, 2012 | Casio Music
Where in europe can I buy an adapter for the casio WK-110 keybord
The specs for the adapter are:
9 volts DC
850 ma MINIMUM
Center pin of connector NEGATIVE
If you find an adapter meeting these specs it should work, however I would recommend getting a regular Casio unit. They are under $20 USD and the part number is AD5.
Jan 02, 2010 | Casio CTK810 61 Key Keyboard
Music Logo
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
