Question about HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled
How do I make my printer discoverable for Bluetooth connection
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Posted on Sep 11, 2014
SOURCE: HP OFFICEJET 6110
no it does not have bluetooth properties.but you can transfer it through usb card driver properties.
Posted on Oct 01, 2008
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
SOURCE: can i print via bluetooth
The optional Wi-Fi and Bluetooth wireless adapters are sold separately. You have to buy that to print on the H470 from the iPhone.
See: http://www.amazon.com/HP-bt500-Network-adapter-Bluetooth/dp/B001F0R1CY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1318140269&sr=1-1
Posted on Oct 09, 2011
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you
