Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Need oil filter number for to20
Oil filter?
Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Feb 15, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
What oil do i need for the engine of my ted20 and also what oil do i need for the hydro / rear end and how much.
use 30w in the engine and for trans/hydraulics use massey m1129 or get the Travellers brand for that m1129, most farm stores will have it.
Jul 04, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
How much oil in gear box of tea20
Exactly 20 liters of normal engine oil not gear oil, put it in at the top near the gear lever
Feb 17, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
Hi,tractor is a petrol one.starts fine runs for about two minutes then dies,have replaced plugs ,striped and cleaned carb .
check the fuel filter insge the tank by unscrewing the fuel shut off valve , clean the gauze filter. be careful ,its wise to drain the tank first, or have a bucket handy as the fuel will drain out.
Dec 13, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
I have a 1950 ferguson to20 lift arm will not lift any weight ? this problem just happened is this a simple fix? like o-rings, check balls??? Thanks
maybe, If the hydro fluid level is up then you most likely need to change or clean the hydro filter. when they stop up they will cause it to cavitate. cavitation will add air bubbles to the fluid and make it look a little milky. It would be best if you can drain it and add new. please let us know if this helps. note that they will usually be jerky on lifting just befor no lift.
Aug 31, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
What sort of oil is used in the gearbox of a massey ferguson 28 Te 20
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Apr 29, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
The tractor will run good and then all of a sudden it will start popping and cracking and won't hardly run at all then it will pick up speed again and run good and then go right back to popping and...
take out your air filter and blow it out and then start the tractor without it on and rev it a couple of times and then but the air filter back on and it should work i had the same problem,
Apr 01, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Trying to find correct distributor for (experts tell me)what we think is a 1952 TO20. A Delco rebuilt sent does not fit. It has a cam around the "shaft", whereas mine is smooth all the way. Maybe it isn't...
I love digging into stuff like this, but I'm out of time here. I'm forwarding something that might help a little. If you can obtain your serial number, this link is a chart to help identify year and origin. TE/TEA20s were built in Coventry, UK and all TO-20s were built in Detroit, USA
I'm interested in your serial number if you can send it in a reply... with that, I'll do some more looking.
Thanks!
http://www.fergusonenthusiasts.com/serial%20numbers/SNRanges_1946_1960.pdf
Sep 23, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
What fluid do you use in gear box
Gear box oil :) 80W/90
Unless it is feed from your hydrostatic transmission.
Jun 14, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
71 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
rostit
ray gallant
Are you a RTO Toy Expert? Answer questions, earn points and help others
