Question about HP PSC 1510 All-In-One InkJet Printer
Windows 7 ink level check - HP PSC 1510 All-In-One InkJet Printer
windows 7 ink level check
5 Related Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: How to check ink level for a hp 1210 printer /vista
  1. Check the back of your computer to make sure that the printer is appropriately connected to the computer and is plugged in. If the printer is not plugged into the computer, find the printer jack on the back of the computer and plug it in before you move on to the next step.
  2. Step 2 Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.
  3. Step 3 Look for the printer/fax icon in the control panel window. Double click on the printer icon.
  4. Step 4 Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
  5. Step 5 Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
  6. Step 6 Click on "Service this device." You will find the button on the Services menu that you just activated.
  7. Step 7 Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Posted on Aug 07, 2009
Anonymous
  • 4090 Answers
SOURCE: I used to be able to check the print cartridges ink levels.
you need to get an updated driver from HP that is designed for Win 7.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
rajdeepdutta
RAJDEEP DUTTA
  • 2517 Answers
SOURCE: how can l check my ink level for my 5510 hp
Dear friend ,
Please go control panel> printer> propertice> your will find the option to see your ink lavel.
Posted on Jan 29, 2010
Anonymous
  • 224 Answers
SOURCE: ink level display on windows 7 64bit
http://h10025.www1.hp.com/ewfrf/wc/product?product=1153754&lc=en&cc=us&dlc=en&lang=en&cc=us&y=7&x=2
check out this link for fixes and help. i would suggest a fresh driver instal if you've not done that alraedy. good luck
Posted on Apr 08, 2010
Anonymous
  • 25 Answers
SOURCE: I have Windows 7 and
You check the printer ink level in HP solution center.
Posted on Oct 15, 2010
Why can't I find the ink level of my HP 7960 printer the way I did with Windows XP?
The ink levels are a feature of the HP software. What probably happened is that when you had WIN XP you loaded the entire software package which included the ink level utility and with WIN 7 you may have only loaded the basic drivers which does not provide this capability. Check the HP support site for a full software package and see if that brings it back.
Sep 18, 2014 | HP new photosmart 7960 inkjet printer...
Can no longer check my ink level.
Sometimes Windows 7 drivers need to be downloaded from the HP support site. Also, make sure you have installed the application on the CD that came with the printer in addition to the printer drivers. That is what you would have run under Programs before. If your Windows 7 computer was not used to manage the printer before, you will need to install the HP management tool on it in order to see ink levels.
Mar 20, 2014 | HP DeskJet 3930 InkJet Printer
I want to check ink levels on an HP deskjet 5650 with Windows 7
Google HP 5650 windows 7 driver go to HP website and download ututlity tools
Dec 07, 2012 | HP DeskJet 5650 InkJet Printer
How i check the cartage level, i am unable to doo that, plz help me...if have to any command direct to see ..please let u inform me..My printer is HP Clour Laser Jet 1600 ...
Check ink levels Use one of the following methods to check the ink levels. NOTE: If you have installed a refilled or remanufactured print cartridge or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable. Method one: Use HP Solution Center to check ink levels HP Solution Center is software that acts as a centralized point of access for tasks such as scanning, printing, and copying. The software is part of the software package that comes with your product. When you perform a standard installation of the HP software, HP Solution Center is automatically installed. You must have the full-feature print driver, which includes HP Solution Center, installed to use this method. If you do not have the full-feature print driver installed on your computer, you can install it now. Alternatively, you can use 'Method two: Check ink levels from the software program' to check the ink levels. Click this link (c02463264) (in English) to see instructions for installing the full-feature print driver and HP Solution Center.
  1. Open HP Solution Center.
    • Windows XP : On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista : On the Windows taskbar, click the Windows icon (c01364735.gif), click All Programs , click HP , and then click HP Solution Center .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Programs , click HP, and then click HP Solution Center .
  2. Click Settings , and then click Printer Toolbox .
  3. Click the Device Services tab, and then click the Estimated Ink Levels tab.
    or try this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&tmp_task=useCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=390328&key=null
Apr 05, 2011 | HP PSC 1600 InkJet Printer
How do I check the cartridge ink level for an HP 6940? I'm running Microsoft Windows 7.
Start the HP Printing Assistant Software that was provided with the printer.
Click Utilities.
Click to check the Ink Levels.
Jan 27, 2011 | HP Deskjet 6940 InkJet Printer
Ink level display on windows 7 64bit
Apr 08, 2010 | HP Photosmart C7180 All-In-One InkJet...
Ink levels
On Windows XP I could see the ink levels however now on Windows 7 there is no way to see ink levels or to clean the print heads. I have to use my iMac to see ink levels and clean the print heads.
Sep 17, 2009 | HP Deskjet 6940 InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
efs_perpends
efs_perpends
k24674
