Question about Nokia mobile C2-00 Dual SIMbiosis
How do i get a packet data connection on c2-00?
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: packet data connection
Contact your service provider for gprs settings of your phone and save that settings when you recieve and start browsing
Posted on Jul 08, 2009
Anonymous
SOURCE: packet data not available on 2600 nokia phone
my Nokia N70 Packet data connection not available error
Posted on Jul 28, 2009
chiefmecha
manuel oliva
  • 600 Answers
SOURCE: packet data connection not available on my nokia
well first of all contact your provider for your phone, they know the settings applicable for your phone, like sip settings, gprs, and or 3g settings etc.
hope that clears your problem
Posted on Nov 18, 2009
vanherringto
J. Van
  • 1738 Answers
SOURCE: when i go to web page on my mobile and connect it
To receive internet service on your mobile phone (called packet data service) you will need a data plan for your phone.
Most cellular providers require that for data service to be available, the customer must request it to be activated on their phone.
If you have already requested data service, contact your service provider and inform them that you are not receiving packet data for your phone.
If you haven't yet requested to have internet service on your phone, you can call your cellular carrier and request that data service be activated on your phone.
Your service provider may have several data plans available for your phone. Take a look at each plan carefully to see what it has to offer.
If you found this information helpful, please give me a big thumbs up when you rate my answer.
Posted on Feb 05, 2010
cilikcelkom
Ahmad Faizul
  • 253 Answers
SOURCE: my nokia x3 cannot connect
first, restore your phone's setting to default. you can find the factory setting on your phone's setting, the standard phone's code for nokia is 12345 ( remember it!! just reset setting, not reset all ). good luck.....
Posted on Dec 24, 2010
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
Packet data connection not available problem in my nokia 5233
Solution ->
  • U have to Active internet Pack
  • Save Configuration Settings
Dec 22, 2010 | Nokia 5200 Cellular Phone
Packet data connection not available,,
Its simple, Just call you Cellular Network Operator's Customer Care & Tell them to Active Packet Data Connection on your Account. They will active service in short period & then you will enjoy Packet Data Connection on your Nokia 2700.
Thanks.
If problem solved please vote me & if its still alive please contact me.
Aug 22, 2010 | Nokia Classic 2700 Cell Phone
How can i remove packet data from my nokia phone, am from Nigeria and i can not access it
hello,if you remove the packet data from your mobile phone that simply means you will not be able to connect your browser,the only thing you can do to the packet data is either to CONNECT/DISCONNECT.
you can achieve this by the instructions provided below,
MENU>SETTINGS>CONNECTIVITY>PACKET DATA>PACKET DATA CONNECTION.from the option there you will see "WHEN NEEDED" you will be asked either to be "ALWAYS ONLINE" OR "ASK FIRST".
TAKE CARE.
Aug 16, 2010 | Cell Phones
How can i set my nokia 3110 paket data
set your packet data,follow this..
1.menu
2.setting
3.connectivity
4.packet data
5.packet data connection
6.select always online
i hope it will help you,thanks for trusting fixya
Jun 16, 2010 | Nokia 3110 Cellular Phone
Iam not able to install bsnl3gmobiletv on my samsungGT-S5603.I live in barmer(rajasthan).Thereis 3g service avaliable here
You musy define three access points.
1. bsnlnet : a) Connection name - bsnlnet b) data bearer - packet data c) APN - bsnlnet d) Authentication - Normal e) Home page - www.bsnl.co.in
2. Bsnl Live - a) Connection name - Bsnllive b) data bearer - packet data c) APN - bsnllive d) Authentication - Normal e) Home Page - www.bsnllive.com
3. Bsnlstream - a) Connection name - Bsnlstream b) data bearer - packet data c) APN - bsnlstream d) Authentication - Normal e) Home page - www.bsnl.co.in
One more to be defined is Packet data Connection - When needed Access Point - bsnlnet
Mar 15, 2010 | Cell Phones
I have a 'G' in the top left corner of my Nokia 6600 slide next to the bettery icon which didnt show on my old phone, can you tell me how to get rid of it please?
The General Packet Radio Service (GPRS) is set to "Always online". Go to Menu > Settings > Connectivity > Packet data > Packet data connection. Select "When needed". The character "G" will still appear when GPRS is used.
Jan 27, 2010 | Nokia 6600 slide Cellular Phone
How can i connect to packet data. im using nokia 6111
check ur settings and restart the phone after sometime if problem continues ask ur service provider
Aug 05, 2009 | Nokia 2600
Packet data not available on 2600 nokia phone
Jul 28, 2009 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
