The shampoo is being dispensed too quickly, the tank is empty before we have completed a small section. We have used the machine many times without a problem Can it be the tank is no in properly.
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
SOURCE: Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
SOURCE: bissell pro heat cleaner
My Bissell did this same thing and it took forever for me to figure out. Seems one of my kids turned the dial that says heavy traffic, normal traffic around and around. All I had to do was turn it back until it wouldn't turn anymore and VOILA!
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
My Bissell also STOPPED SPRAYING WATER.
I've owned a Bissell 9200 for a few months. I've used it twice, the last time most likely being around August. I attempted to use it this past weekend and it wouldn't spray. I searched all the help sites I could find and thought the solution was a clog in the heater, which many said was located in the arm. After I took the arm apart, to my surprise, THE HEATER IS NOT LOCATED IN THE ARM OF THE 9200 MODEL.
It's still under warranty, however am not located near a service center so I took it upon myself to try to fix it.
I'm just a single female who ends up trying to fix a lot of stuff herself so, I don't speak "technical instructions". But, here's what I did in the event that it may help someone else.
I unscrewed all the screws that I could on the base. I removed the cover over the motor. Doing so revealed the hoses attached to the soap dispenser. Located closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the where the HEATER is located.
Being that I was looking for a clog, I unclamped one hose at a time; inserted a safty pin into what the hose was attached to and wiggled it; re-clamped hose afterwards.
The only slight confusion may be with the screws. There are only two sizes. I used finger nail polish to mark where the small ones went.
I reassembled it, turned it on, and it actually started spraying again!!!!!!!!
So that this "blockage" won't occur again, I will take advice I've read about cleaning Bissell's hoses out after using it.
See, taking the thing apart was really nerve racking! Especially not knowing if it would even work after I put it back together.
GOOD LUCK WITH FIXING YOUR CLOG!....you'll probably need to sooner or later.
SOURCE: Flow Indicator Not Moving, Not Dispensing Anything
The water tank and the solution tank both have red gaskets that attach to the bottoms of the tanks. Make sure they are on properly, I just had the same problem and spent hours taking apart the machine and inspecting lines to find out it was a gasket.
On my machine the red gasket for the solution got stuck in the chasis for the machine. The bissel website alludes to this, but isn't very clear.
Other posters talk about the heaters, or the lines being clogged and I immediatley inspected these areas, turns out it was a gasket that was hiding in the chasis. Both the water tank and the solution tank should have one, and make sure they don't get nestled in the chasis!
SOURCE: water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
