Televison & Video Logo
Question about Alba Televison & Video
I require manual for
Model 1006/D I require the operating instruction manual
1 Related Answer
Anonymous
SOURCE: need a instruction manual for a panasonic DMR-EZ47V
I need an instruction manual for DMR-EZ47V.
Posted on Feb 17, 2009
1974harley with a super B carb it spits two or three times on a ten mile run, some times when you come to stop. it is a 1974 super glide
My first inclination is tell you that it is probably jetted too lean. The low speed jet should be a number 29.5 or a 31. The main should be a 72 in most cases. Your bike may require a step up or down from these jet sizes as I don't know what kind of exhaust or other modifications your bike has nor the location (altitude) you are at. This is a common complaint with the Super "B". The biggest reason for this is that the Super "B" carb did not have an accelerator pump on it. This means that when you rev the engine, you create a momentary lean condition before the vacuum signal can start to draw fuel from the main jet circuit. Go to S&S's site and download the installation instruction for your Super "B" carb, file 51-1006. Even though they have stopped production of this model, the instructions are still posted online. The Super "E" carburetor was designed to replace the "B" model. The "E" is called the "Shorty" because it is much shorter and does not stick out as far as the "B" model. It also has an accelerator pump that smoothes out the transisition between the idle-low speed circuit and the high speed circuit. Also, check your plugs, plug wires (especially the spark plug boots and the end that plugs into the coil) and the points. You may be getting a misfire or a weak spark.
http://www.sscycle.com/uploads/instructions/51-1006.pdf
Good Luck & Ride Safe
Steve
I was Given a sony tv projection model no kp-44px3u and require a user manual guie can you help
SONY CRT Projection television.
This looks like an 'Asia' model probably used in New Zealand.
You can get a manual by going to;
http://www.sony-asia.com/support/product/kp-44px3u/manual
Then click on the Operating Instructions link.
» Operating Instructions
File Size: 1.43 MB
Part Number: 4-102-591-41(1)
Date: 31 Mar 2004
English
2answers
Looking for manual for panasonix FH20 Lumix camera
Need to know which part of the world you bought it. That model number is unknown in the USA Canada, and UK websites for Panasonic.
Oct 27, 2010 • Cameras
1helpful
We're looking for an operaters- or owners manual for our model# JM5549I, the ser.# is 41101890 Your help is appriciated; [email protected] W.Rutgers 1006 Aspen Dr. Brockville, ON, K6V 7G2
What is the make of your unit? The model number you passed did not cross JM5549I. If you could check it once again please it would be a big help in our ability to help you.
There are two sites that you can check for your manual at the moment but you will need brand name and model on the sites
1. http://www.retrevo.com/samples/index.html (Choose brand) then enter make and model.
2. http://kitchen.manualsonline.com
(Make and model required top of page)
2helpful
Operations manual required
hi, you can download the user's manual here:
http://safemanuals.com/brand-user-guide-instructions-owner-manual/RUSSELL%20HOBBS
when you go to this page you will find "
List of the top manuals RUSSELL HOBBS (user manual, user guide, operating instructions, instructions for use & instruction manual)
written on the right hand side of the page insert your model number and download it
plz do not forget to vote and click yes if i solved your problem,much thanx! :)
Aug 29, 2009 • Juicers
JUST BOUGHT ACER ASPIRE ONE A150-1006 PC NOTEBOOK NO MANUAL DO NOT KNOW HOW TO OPERATE WEBCAM
This is what acer says about working with inbuilt webcam
http://netbooks-us.custhelp.com/app/answers/detail/a_id/61/session/L3NpZC9zOHp2eVREag%3D%3D/page/2/r_id/166/sno/0
I have no idea how to use the built in web cam
Press on the FN + F1 key. It will show you instructions on how to use the webcam. If it does not come up then click on start>Control Panel>Display and the webcam instuctions will be available. Good luck.
Don't forget to rate this 4 stars before you log off.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
