It is a strange unit in that it takes 3 different sizes of battery. My guess is that the battery cassette is not in place correctly, turn 90' and try and then180' and try.
Remove the tail cap: Turn the tail cap counterclockwise to loosen and remove it.
Remove the old battery: Take out the old battery and dispose of it properly.
Insert the new battery: Insert a fresh double A battery into the flashlight, making sure the positive (+) and negative (-) ends are facing the correct direction. The positive end of the battery should be facing the head of the flashlight.
Replace the tail cap: Turn the tail cap clockwise to tighten and secure it.
It is important to use fresh, high-quality double A batteries in your Liteum 40222 flashlight to ensure optimal performance and to prevent damage to the flashlight. Make sure to dispose of the used batteries properly, following your local regulations and guidelines.
please attempt to twist the top or the bottom of the flashlight off in order to open it and the batteries that you've mentioned. Otherwise, you can drop buy your local geeksquad/bestbuy to have a tech do the battery replacement for you.
To let you know that it's charging It will turn solid red or change to a different color when the charge is complete
I bet if you read the paper work that came with flashlight it will explain the operating functions.
To my knowledge this item has been discontinued by Coleman and is no longer available. However, I've listed basic instructions on changing batteries. Here's a link that you could watch for the disassembly for your flashlight type.
Locate the battery compartment on the Coleman CT 50 flashlight. This is usually at one end of the flashlight and is secured with a cap or cover.
Depending on the design, unscrew the cap or remove the cover to access the battery compartment. Some flashlights may have a twist-off cap, while others may have a sliding cover or other mechanisms.
If there are existing batteries in the compartment, carefully remove them. Pay attention to the orientation of the batteries, noting the positive (+) and negative (-) ends.
Insert new batteries into the compartment, ensuring they are placed in the correct orientation. Match the positive and negative ends with the markings inside the battery compartment.
Once the new batteries are in place, securely put back the cap or cover. If it's a screw-on cap, tighten it until it's snug. If it's a sliding cover, ensure it clicks into place.
Turn on the flashlight to check if the new batteries are working correctly. If the flashlight doesn't turn on, double-check the battery orientation and make sure the connections are clean.
If the old batteries are disposable, make sure to recycle them properly. Many communities have specific recycling programs for batteries.
Always refer to the user manual or any included instructions for your specific flashlight model, as the steps may vary. If you don't have the manual, you can often find it on the manufacturer's website or contact Coleman's customer support for assistance. Additionally, be mindful of the type and size of batteries recommended for the flashlight to ensure optimal performance.
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Either the battery is out of power or your flashlight is malfuction. Firstly you need to buy a new battery to check the real issue. If the new battery won't change the situation, that means there is something wrong with your flashlight, therefore you may plan to pucharse a new one. If you don't want to spend much money on it, you can think order one from online store. I recommend the following headlamp to you: http://www.aurabuy.com/bright-76-led-4-modes-led-mega-headlamp-4xaa.html
