Unplug it. Carefully take off the grill and use a vacuum and/ or a damp cloth to clean the blades etc. Do not soak with water. Just a DAMP cloth on the blades only!!!!
The area you have highlighted is the CHASSIS FAN and is almost completely blocked by dust. Looking at the other photos, the entire inside of the pc is very dusty. Use dry, compressed air, MUST BE DRY AIR as any moisture in the compressed air may damage critical components. You need to blow the dust out of the cooling fan as well as the entire inside of the pc. Blow dust out of any other cooling fans you see around the same area as well as the fan in the power supply. Don't be afraid to use a lot of air to clean the inside but be very careful not to introduce moisture. When you are finished, there should not be any dust left in the machine. If there is dust or dirt that will not blow out, it has been hardened by humidity in the area where the pc is kept. If you keep it on the floor under a desk or in a similar area, make sure to raise it at leas a foot off the floor and clean it at least every 2 months. Hope this helps!
OH, NO. It gone south faster than Willy the Coyota trying to catch the Wild Road
Runner. It's kaput, finny, it died, Don't throw it way. Please recycle it,
copper is $3.25 per/lb, brass is $1.85 per/lb.
If you don't fill like stripping this China made Stanley Blower. There are
charitable organization; such as, Boy Scouts, Girl Scouts, Church's, recycling
centers, etc. Sorry. GB you....stewbison
Make sure there is no lint or dust in the fan motor located on the lower back of the fridge. If you clean the fan of lint and dust it should help evaporate water in drain pan.
#1 CLEAN WORK SPACE
#2 PLACE FAN ON ITS CONTROL SIDE DOWN
#3 REMOVE PHILLIPS HEAD SCREW FROM HANDLE
#4 REMOVE NON-SKID COVERS
#5 REMOVE OTHER 2 PHILLIPS HEAD SCREWS
#6 REMOVE BLACK SIDE & CLEAN
#7 REMOVE YELLOW FAN COVER & CLEAN
#8 7/16 SPIN-TYPE DRIVER REMOVES FAN NUT
#9 CARE....WASHER ON OTHER SIDE OF FAN
#10 PUT FAN IN SOAP& WATER ....TAKE YOUR TIME
If you remove the cover screen and take compressed air or just a brush to clean out all dust and dirt from the motor the fan may run again
Dust is a standard contributor of these fans to quick turning
Dust is evil to all mechanisms!! Keeep UNPLUGGED..then Vacuum all accumulated lint in fan motor assembly, and soak with WD-40...I just did detailed dust cleaning with toothbrush....Fan now runs awesome!! Good Luck
