Had just replaced ink cartridge and started getting message
SOURCE: I keep getting an error message- unable to clean
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
SOURCE: Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
SOURCE: Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
IT means you need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
