Question about Apacer Memory Apacer DISC STENO CP200, Portable Photo CD Burner (GXMRADCP200) Burner
How do fix the lcd display that does not light up
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
LCD display has stopped working
More than likely only a new display will fix it, it is that whole front silver panel with the buttons and display plus a big part of the wiring loom going lots of places inside the machine.
Apr 09, 2013 | Krups Super Automatic XP 9000 Espresso...
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
Mar 19, 2012 | Pioneer Audio Players & Recorders
Ford 2000 Crown Victoria: radio display is dark. How to fix? Radio is out of car; top and bottom covers removed.
This might be a problem with the radio's back light or the actual LCD layer. The LCD would have your display and the backlight provides the light for the display to be visible. They might be dirty or would need replacing.
Apr 11, 2011 | 2000 Ford Crown Victoria
The washing machine works perfectly fine. however for the lcd screen no words show up but there is still a light. how would i go about getting this fixed? cheers x
hi penie92 .Just read your posting.For the LCD screen not to show any characters then I am afraid you need a new display board.Could you please tell me what light is lit?Is this the light for the LCD display?Please reply with additional information and I can help you rectify this fault.
Jun 24, 2010 | Washing Machines
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
Display dim
it was the display ic., and combiner to produce lights it got grounded ..gotta go to center and fix the light combiner or capacitor..or the display ic... but if it is backlight problem of the lcd.. go to the light combiner capacitor and not to the ic..
Apr 15, 2008 | Sony Ericsson W850i Cellular Phone
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
LCD's won't power up
The LCD not displaying a picture may just have a back-light issue. You can verify this by turning on the display, taking a flashlight and pointing it at the LCD then looking at the area that is illuminated on an angle and up close (1" - 2"). If the picture is visible then it is a back-light. You either need an LCD back-light inverter or the back-light itself.
Nov 08, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Apacer Memory Apacer DISC STENO CP200, Portable Photo CD Burner (GXMRADCP200) Burner Logo
83 people viewed this question
Top Apacer Memory Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Apacer Memory Computer and Internet Expert? Answer questions, earn points and help others
