Question about Health & Beauty
I have 7 flashing light warning on an eden bootmaster scooter, anyone confirm the fault code, is it a fault on the speed potentiometer/pot ? a full list of error codes would be useful ?
Anyone have a list of the fault codes ,thanks
Gino Borg
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
7 flashes could be speed or throttle, i recommend replacing both.
Posted on Nov 06, 2014
5 Related Answers
Neil Wood
  • 177 Answers
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
Posted on May 30, 2010
gewiz
Rob Hill
  • 1414 Answers
SOURCE: pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Posted on Jun 13, 2009
oregoon
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
Anonymous
SOURCE: mobilty scooter fault
i have a shoprider mobility scooter has soon has i turn on it goes about 5 yards and stops and the alarm comes on i think it has something to do with the brake system could anyone advise me on what it could be thanks
Posted on Sep 21, 2009
Neil Wood
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning [email protected]"
IRN50H-OF Getting random VSD Fault 22 and VSD Fault 36 does anyone have a published list of fault codes, or know what these mean?
Not that I am aware of and we have no way of looking any up as we do not know the MAKe /model try Google
Apr 04, 2016 | Air Tools & Compressors
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Fault code list for Jaguar XK8
Hi there:
I suggest visit this LINK about Jaguar fault codes.
Hope helps.
Feb 27, 2013 | 1999 Jaguar XK8
Bmw 2882/3 fault codes present
You most likely have an engine vacuum leak or a defective mass airflow sensor or low fuel pressure. Read the codes with a OBD2 code reader and see what the standard codes are.
Oct 14, 2012 | Cars & Trucks
Fault code for LED flashes?
I would GOOGLE the model number to see if manual or error codes are available or search for the NEC site to see what information they have for you.
Mar 14, 2012 | NEC MultiSync LCD4010 40 in. Television
I have a 2000 dodge stratus; with a code of P1494 if anyone could help me.. id highly appreciate it.. especially since the dummies at Autozone have no idea ): thank you ! ----
According to my code list for Chrysler products:
­ Leak Detection Pump Switch or Mechanical Fault
Sounds like a fuel system problem relating to the fuel pump.
May 11, 2011 | 2000 Dodge Stratus
I need the fault codes for 1997 mitsubishi delica
Below is a link to a web site that has a list of ODB codes
The first is for Mitsubishi.
The second is a list of generic OBD codes.
Hope this helps.
http://www.engine-light-help.com/mitsubishi-check-engine-light.html
http://www.engine-light-help.com/generic-check-engine-light-codes.html
Sep 06, 2009 | 1997 Mitsubishi Diamante
Fault code p0251
hi there,
the fault codes you listed correspond to these..
.P1000 ..OBD Systems Readiness Test Not Complete
P0251 Injection Pump Fuel Metering Control.
hope this helps, if so, can you leave me feedback please
Aug 21, 2009 | 2002 Jaguar S-Type
Blinking lights list of faults
Not really. There is just the blinking red lights: usually power issue or motherboard issue.
And the YLOD, usually releated to a video chip problem but it's always a hardware defect which causes that one.
Feb 16, 2009 | Sony PlayStation® 3 (60 GB) Console
What is this F-! mean
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Sep 03, 2007 | Magic Chef CER3725AA Electric Kitchen...
Health & Beauty Logo
314 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
