Question about Vtech Communications Inc Dect 6.0" Three Handset Cordless Phone Answering System
How do I fix my handset when it's flashing back and forth. See manual and To resister HS
Posted by Anna Wiebe on
Lynn L
    New Friend:
  • 4 Answers
Do you mean the red light at the top of the phone? On my phone when the red light blinks on the handset,that means there is a new call on the answering machine:)
Posted on Sep 29, 2014
Where is the HS LOC button on the Clarity E814CC base phone
The Clarity E814CC doesn't have a Handset LOC button; it uses the Paging feature to contact the handset. To locate all of the handsets, press the Page/Flash button on the base with the phone system in idle (no calls in progress). The Page/Flash button is to the left of the Answering System On/Off button on the right side of the base. The button is almost aligned with the 1, 2, 3 number keys.
After you press the Page/Flash button, all of the handsets will sound the Paging tone and their screens will read "Paging". Press Talk/Speaker Phone on a handset or Page/Flash on the base, to cancel the Paging.
The Find the Handset information is in the manual on page 18. The location of the Page/Flash button is shown on page 8. The manual is available from Clarity Products here: http://shop.clarityproducts.com/products/clarity/e814cc/?cat=clarity . Click on the Owner Support tab. The direct link to the manual is http://shop.clarityproducts.com/media/ext/products/assets/E814CC_UserGuideEnglish_RevA.pdf .
I hope this helps.
Jan 10, 2018 | Clarity Lands Phones
How to register hs
It would help to have the model number of the base ( found on a sticker on the bottom of the base ) and the handset (under the battery) but the following works for many models: Press and hold the "Find Handset" button until the "in use" lamp comes on. Press the
"#" key on the handset, then place it on the base... if it is going to work, in a minute or less it will chirp and announce "handset registered". If it shows "registration failed", the base may be "fully populated" and cannot accept another handset: many models are limited to only 5 handsets. To start over by clearing the base registry, press the "Find Handset" button until the "in use" lamp
lights, then continue to hold "Find Handset" until "in use" begins to
blink. Release, then press again the "Find Handset" button for a moment. The base should chirp, and be ready to register handsets again... try again as above until the maximum is reached. Good luck!
Apr 06, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
VTech CS6409 register handset fails with no message
From what I read it seems you are trying to register and add a new handset to your system. I am also assuming that the handset is de-registered.
A common problem with registering a handset to this system is Owners Press and Hold the # sign before releasing it. This button is to Press and IMMEDIATELY release. DO NOT HOLD. If this does not solve your problem then
With a charged battery in the handset, the display should read "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" if it say so, then when you press and "IMMEDIATELY RELEASE " the # sign on the handset the information should change If the screen goes blank when you do so and return to "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" then you will have a bad battery or your base memory is full.
Replace the battery and try again. If no change then
The best way to go is to clear the system and re-register all the handsets. Begin by removing any handset from the main base cradle. Then
Press and hold /FIND HANDSET on the Main base until the IN USE light turns on and starts to flash. then release it, then without pause Press and Release it again. That will clear the system and de-register all your handsets.
All handsets will show 1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET. To re-register follow this instruction
Jun 02, 2017 | Vtech Lands Phones
Handset msg says.."Press HS LOC
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here. The manual should have illustrations giving the locations of all buttons.
Sep 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Have a V-Tech 6.0 phone CS6319 Series - Battery OK - turns on, but NO DIAL TONE. We do not have manual, Do not see anything like Mute On/Off in menu. All connectors and plugs are secure. Help?
First, does another phone get a dial tone at the jack in question? (I prefer an old corded phone for this test since it is unlikely to have some of the problems of a cordless.) Try a new phone cord between the base and the jack. If there is no dial tone, try the test phone at other jacks. If there is no dial tone at any jack with either phone, find where your telephone service comes in and open the service box. If you are lucky and have a fairly new connection, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for dial tone. Otherwise you will need the phone company to do this test. If there is no dial tone at the service box, your phone company will fix the problem for you for free.
If your test phone works:
Make sure that the base is plugged into a working outlet (no tripped circuit breaker, turned off power strip). Next check that the handsets are registered with the base. To register the handset, press the Find HS button on the base (below the in use indicator) for 4 seconds, then press # on the handset. (Our cordless phones once lost their registration during an extended power outage.) You can force deregistration by pressing and holding Find HS for 10 seconds. The In Use light should come on and flash. Then release the Find HS button and then press and release it again while the In Use light is blinking. You may need to try unplugging the base after pressing Flash/Talk and then Off/Clear before deregistering the handsets. The register the handsets.
You can Mute the microphone on the handset with the Mute button. To silence the ringer, press Menu/Select when the handset is not in use. Use the up/down arrow keys to select Ringers then press Menu/Select. Then press Menu/Select to choose Ringer Volume. Use the up/down arrows to change the volume and then press Menu/Select to confirm and save the setting. This should not change the ability to hear the dial tone.
If your test phone works at the service connection but nowhere else, then you have a wiring problem inside. Check exposed wires if you have them. Your phone company will offer to fix the issue for a fee. If the problem is at one jack, open the faceplate and check for loose wires. Some faceplates use a keystone with a punch-down tool to secure the wires. Others just wrap the wire around a screw for each pin.
If the handsets are registered and the base has power, then the cordless phone has problems. If it is under warranty, have it fixed. Otherwise, replace it; they aren't made to be user serviced.
The manual is available here: http://www.vtechcanada.com/support_docs/vtt/CS/CS6319_en_cib.pdf .
I hope this helps.
Apr 22, 2011 | Cell Phones
I have a TRU9466 with 10 handsets. 3 of these hand sets have quit working. I have the correct replacements but the base will not accept any more units. (limit 10). Hence the issue, since the original HS...
As far as I know you can't deregister all of the handsets at once. However, if you know the handset numbers of your good handsets, you can exclude them and deregister the others one at a time. Press and hold Call End and # for more than 5 seconds on a working handset. Select DEREGISTER HS and press the OK soft key. Scroll down to select a handset number when you see the Which HS? prompt. Select Yes and press the OK soft key. Repeat the Yes and OK at the "Are you sure?" prompt. Press Call End. Press Menu and select Deregistration. Press the OK soft key. Then select Yes and press the OK soft key when you get another "Are you sure?" prompt. This is shown on page 61 of the manual. You can find the manual here: http://www.telecomuserguides.com/manuals/filesupload/Uniden/5_8GHz_Digital/TRU9466om.pdf .
I hope this helps.
(Since the method above works for lost handsets, it should work for handsets that can not communicate with the base.)
Feb 08, 2018 | Uniden TRU9466 Cordless Phone
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Tried to reregistering
Hi
Please try the following procedure:
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Vtech Communications Inc Dect 6.0" Three Handset Cordless Phone Answering System Logo
119 people viewed this question
Top Vtech Communications Inc Lands Phones Experts
Marvin
Marvin
k24674
Are you a Vtech Communications Inc Lands Phone Expert? Answer questions, earn points and help others
