Question about Kenmore Elite 44173 30 in. Electric Cooktop
All my controls are blinking on my kenmore elite counter cooktop
It won't work, don't know what to do???
Posted by Kirsten sandner on
1 Related Answer
Panchote
  • 92 Answers
SOURCE: I need black control knobs
Here is the link. http://www.searspartsdirect.com/partsdirect/brands/Kenmore-Parts
Posted on Jan 12, 2011
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
How to remove oven thermostat on whirlpool stove
You don\'t need to remove the top. The thermostat is the long skinny tube in the oven that comes up to the railcock behind the oven control knob, remove the front panel to get the railcock/thermostat out which has the tube attached to it.
Mar 20, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
A hotplate on old Westinghouse Silhouette electric cooktop won't turn off. Is this easy to fix? Any help appreciated we have young kids.
one of your thermostats has stopped working. no easy fix. you can just disconnect the plate and work without it.
Sep 14, 2012 | Cooktops
We need to know how to get to the igniter in the oven?.
First of all, you don't need to mess with that, call your gas company.
Aug 28, 2012 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
The blower won't turn off on the grill side of the stove. I changed the switch but the blower stays on.
Since I don't know your model number, I will have to give you deneric advise. Some fans have a thermostat that will activate the fan when certain temperatures are met. If yours is like that, then the thermostat could be the cause.
Jul 05, 2011 | Jenn-Air Cooktops
I don't know how to connect to the wall plug
I think that I would get an electrician if it isn't a straight forward plug
Jun 10, 2011 | Neff T1323 Electric Cooktop
Kenmore Elite 44173 30 in. Electric Cooktop Logo
110 people viewed this question
Top Kenmore Cooktops Experts
Michael Thomas
Michael Thomas
jdthefixer
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
