Question about Jacuzzi Home
Jacuzzi has power but does not work panel has three bars instead of tempeture reading any suggestions
Posted by lemay on
US Parts Center
  • Jacuzzi Master
  • 719 Answers
Those 3 bars usually indicate the circuit board is not working properly and will need to be replaced.
When you say has 3 bars this is what that shows. - - -
Posted on Feb 09, 2015
1 Related Answer
Randy Marshall
  • 349 Answers
SOURCE: sudden loss of power
Check for any GFIC receptacles in line some where tripped out. Check breaker and make sure it's working properly.
Posted on Jun 10, 2010
The fridge section is not working, the led horizontal indicator bars are not illiminating, on the control panel. Any ideas please.
check ur air flow control knob and or ur cold or tempeture control thermostat, sometimes the air flow vent is closed or open to far one way? also check to see if fan in freezer is working?
Mar 11, 2015 | Refrigerators
How to pull off all three knobs from control panel
The knobs on the jacuzzi whirlpool pull off.
US Parts Center
May 30, 2014 | Jacuzzi Home
Do I have the correct controller for my Hot Tub? I have a Jacuzzi Lexus L.C. with a Balboa F1089R1A processor. I ordered a topside control panel online and received a Balboa VL701S but nothing is working...
Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Nov 13, 2013 | Jacuzzi Home
Three button control panel for jacuzzi tub
Pull off all three knobs and then the plastic graphic rings and you will find 2 screws under each. After removing the screws the whole plate can pop off. If your problem is anything like mine, your air pump is full of water and needs to be replaced. After removing all the screws you can carefully pry it up with a thin tool, it is most likely caulked to the tub. You can find replacement parts and names for it here:
http://www.guillens.com/index.jsp?path=product&part=124772&ds=dept&process=search&text=JAC%20%20G107XXX
Hope that helps
Apr 28, 2012 | Jacuzzi Home
Sudden loss of power
Jun 09, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Pump will not work in high speed
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Feb 12, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Home Logo
134 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
