Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis skips rinse cycle and goes from 17 min to 4
Posted by Randy Totten on
5 Related Answers
Anonymous
  • 326 Answers
SOURCE: Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
Posted on May 06, 2009
rallyb33
  • 6 Answers
SOURCE: I have a Kenmore Elite Oasis HE washing machine
could have a blocked drain/ coin trap. Look under the washer behind a panel or in the back. You may have to take out screws
Posted on Oct 23, 2009
jimorris77
  • 411 Answers
SOURCE: Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Posted on Nov 20, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Regarding Kenmore Oasis mod. 110 27072600 Ser.
LF is a failed water inlet valve either hot or cold sets the code, try using just hot then just cold settings and see if the code goes away, if it does then the hot or cold water solenoid valve at the back of the washer is defective
Posted on Sep 16, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 22882 washer won't rinse, drain or spin
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ld signal
ld means long drain, could be a bad pump or something stuck in it.also if drain hose is too deep in the drain a syphone can cause this
Jun 22, 2008 | Kenmore Oasis 27042 Top Load Washer
AWM1404/4 whirlpool skips wash programmes
try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Mar 19, 2008 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
