Question about JBL CREATURE II Computer Speakers
Can you post the circuit diagram of jbl creature ii?
I want to connect a sattelite speaker as a replacement for my jbl creature 2
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Power Cord for Creature II
I looked and the only thing I could come up with is to e-mail JBL and order a new one. Radio shack, Best Buy, or Futurehsop might be able to help but you have to call them with the model number or go to the store and check it out. Here's the link to JBL if you want to order a new one.
http://www.harmanaudio.com/search_browse/partlist.asp?BrandId=JBL&MarketId=HOM&Parts=CREATUREIIBLK/230
Sorry, wish I had a better answer but there isn't much out there for this.
Posted on Jan 05, 2008
Phone_Fundi
Ian Surgeon
  • 91 Answers
SOURCE: JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
Posted on Jan 18, 2008
Anonymous
SOURCE: JBL Creature 2 Blowing Fuse
I think you made a mistake with your fuse.
With my JBL i can see 9,5A 41FU.
Posted on Sep 08, 2008
Anonymous
SOURCE: My left JBL Creature II speaker has a green light
I had the same issue and applied ezimme solution from Jan 04, 2009 and it worked perfectly. Thanks ezimme!
Posted on Oct 16, 2009
stijnsg
  • 15 Answers
SOURCE: Diaphragm problem
Yes it can be replaced and your system will be as good as new afterwards.
To get an idea of the work involved: http://www.audiofriends.nl/pdf/refoaming.pdf
There are several companies selling these so called surrounds. There are foam and rubber surrounds. Stick to the same material as you may otherwise significantly alter your system's sound. Just google "speaker repair" or "speaker surrounds" and you will find several. You can ask them to repair your speakers (which may be fairly expensive) or you can order the surrounds and glue (you can not just use any glue) and do it yourself.
I have done such repairs a few times myself and it is absolutely not difficult.
Good luck.
Posted on Nov 09, 2009
How many input voltage do i need for my jbl creature ii.is it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
Mar 16, 2014 | JBL CREATURE II Computer Speakers
Diagram
http://www.schematicsforfree.com/archive/
schematics
http://www.schematicsforfree.com/archive/dir/
patent directory
i was unable to locate the specific diagram for jbl speakers or any speakers
you might be able to find it
hope it helps
May 07, 2012 | JBL CREATURE II Computer Speakers
The tweeters on my JBL Creature speakers has been damaged ,,do you think it can be fix?
Send them back to manufacturer to fix they will more then likely have to replace the tweeters
Nov 26, 2010 | JBL CREATURE II Computer Speakers
Am looking for a power cord for my jbl creature speakers...thax
Just buy the replacement cord, and put it in place. Send your e-mail if this work and your vote for the
solution.
Sep 27, 2009 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
Oct 27, 2007 | JBL CREATURE II Computer Speakers
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
JBL CREATURE II Computer Speakers Logo
Top JBL Audio Players & Recorders Experts
Bob Kirkwood
rhodesworks
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
