Question about Kitchen Appliances - Others
<!-- from fixya rte -->Not sure how to clean heating element - Kitchen Appliances - Others
Treefrog15
    Habit-Forming:
  • 130 Answers
There are various fryer cleaners or degreasers that can be used. In most cases, the fryer is drained and wiped out, filled with water, and the appropriate amount of cleaner is added. Usually, the fryer is turned on and the cleaning solution is boiled for a time. Follow the directions for the cleaner. If heated, be careful that it does not boil over. A nylon scrub brush can be used if necessary but not metal scrubbers or utensils. Repeat if necessary. Rinse thoroughly with clean water. Use protective gloves when working with fryer cleaners and be careful not to get the cleaner on painted surfaces, aluminum depending on cleaner's instructions.
Posted on Sep 23, 2014
1 Related Answer
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: not sure how to clean heating element
Yes you can get it wet, but make sure it is dry before you turn it on. If the element is detachable, that is good. If not, you may not be able to put it under water because water could get into the electrical components. There should be a caution tag on it that tells you if you can put it in water. One thing you can consider is drain the oil and put in water with a cleaning agent and then turn it on and let it come to a boil, then shut off and do this several times. This will remove a lot of the build up on it.
Posted on Mar 04, 2009
Dishes are not clean after cycle, not sure what to do , opened in middle of cycle and steam comes out so water appears to getting hot, not sure if rotors sprayers are turning how can I tell, washer is...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 11, 2011 | Frigidaire Dishwashers
Making a noise and not cleaning very well Can i take apart the dishwasher and clean it and make sure that the drain is not clogged?
Dishwasher
How to Buy
heatman101
Jan 17, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
8 year old maytag, clean lime build-up 2 times a year and all the spinning parts look clean and no wear but all of asudden the washer does not clean the dishes very well. Plenty of hot water, soap is...
In you case check the heating element first...
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Sep 23, 2010 | Maytag Dishwashers
Not cleaning properly i cleaned filter used a cleaner still wont clean dishers properly
Dishwasher Spray Arms not Spinning
heatman101
zt5534
Aug 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
DISHWASHER NOT CLEANING
heatman101
Mar 08, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My dishwasher is not cleaning the dishes. its not making the same sounds as it use too also. we have tried cleaning it and making sure its not clogged. nothing has WORKED
heatman101
b
Oct 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Fridgidaire professional series drain smells and won't clean
heatman101
nmsgjh
Jun 18, 2009 | Electrolux Frigidaire Professional Series...
My Maytag jetclean dishwasher is not cleaning the dishes and the soap is not dispensing. I am also not sure the water is coming in? Help?
heatman101
a
Jun 10, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishes not clean and leaks sometimes
heatman101
Feb 03, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Kitchen Appliances - Others Logo
83 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
