I have a new f126 but it won't take pictures. Nothing happens when I press the shutter button. What do I need to do?
SOURCE: my the shutter release button isn't working
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
Jim Silva
SOURCE: No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
SOURCE: No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
SOURCE: nikon d40 autofocus
Dan62, your camera will never be able to focus on objects with no contrast. The manual specifically states this. However, you can put the AF marker over something with some contrast, half press the shutter, so that it will focus, hold the shutter button halfway while you recompose the shot, and then press it all the way.
A note to others using the D40/D40X/D60 that are having problems with autofocus: please remember that this camera will not autofocus with mechanically driven lenses. It will only AF with "AF-S" or "AF-I" lenses.
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
