Brush will not spin belt is new belt is spinning
HI, it's Jim from Crucial Vacuum!
If your belt is rotating and performing properly but your brush roll is still not turning or functioning properly then there may be a clog. Usually you can fix a brush roller with a quick cleaning or by oiling it's bearings however once the bristles endure too much wear and tear, it is time to replace it. Is there any noticeable debris caught in the roller? Long strands of hair, or carpet fibers? If so use a scissor or a razor to cut away the blockage. Then manually rotate the roller to see if there is any further debris. Make sure the vacuum itself is in the reclined position, otherwise it won't turn at all.
You can purchase your replacement Eureka parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
The brush will not spin in the handle is in the upright position. Release the handle and see if it works. If you have a carpet floor switch you might want to check that and make sure it is on carpet.
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
SOURCE: beater brush won't spin but belt is intact and ok.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
SOURCE: Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
SOURCE: roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
SOURCE: Bruch will not spin
Make sure the brush switch on the canister is in the on position. The handle must be reclinded for the brush to spin.
