Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
SOURCE: How to do I transfer pictures from my internal memory to my memory stick?
Without looking for a manual on your camera, normally there is function in your camera menu to copy or transfer over to your memory stick, or maybe you can transfer the picture firstly to your pc(if you have one), then back across to your stick, by simply drag n drop as normal.
SOURCE: transfer pics from internal memory to memory stick
hi! I think the question was How to transfer INTERNAL memory not the MEMORY STICK. The memory stick is easy, you just attach it to the "USB PORT." The thing is without the installer, I can't seem to access the INTERNAL MEMORY through my computer. You can view it through the camera and attach it to a compatible pictbridge printer otherwise it is stuck. I was hopnig you had another option. Please help!
SOURCE: internal memory
Insert memory card in camera, go to camera menu, there is option Copy, select copy and transfer images from internal memory to memory stick.
2nd option is connect camera to computer by usb link without memory stick, go to my computer then removable disk, then picture folder, copy pictures and paste them on My Pictures.
Need further help, let me know.
SOURCE: converting internal memory to memory stick
Put memory stick in camera, power up, press Menu >> Copy >> OK
That will copy internal memory pictures on memory stick.
SOURCE: I have transfered some pictures from my memory
Please clarify: from where to where did you transfer and you wish to transfer? Are you using a USB cable from the camera to the computer? Do you mean the memory card that fits inside the camera?
If you mean transfer photos from the camera via the computer to a memory stick, then the problem may be solved in two steps: First download the photos to your computer. Then from the computer to the stick.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
