Question about HP OfficeJet 4255 All-In-One InkJet Printer
<!-- from fixya rte -->Waht is the fix for 49.FF09 Service Error - HP OfficeJet 4255 All-In-One InkJet Printer
pcfixup.ca
    Sergeant:
  • 269 Answers
You didn't describe your operating environment so difficult to get specific. I found this HP document for possible fixes to 49.xxxx errors:
http://h30499.www3.hp.com/hpeb/attachments/hpeb/itrc-219/44130/1/280425.doc
Posted on Sep 09, 2014
3 Related Answers
Anonymous
SOURCE: 49.FF09 SERVICE ERROR
I have a Hp 4100mfp that I am trying to us a Fast Infrared (FIR port) to connect to my Toshiba laptop. My laptop is not picking up this infrared device. Are their any infrared drivers that are compatible with my Windows XP? I've tried the 98 version and it doesn't work. Help please.
Christina
Posted on Jul 17, 2008
Anonymous
  • 9 Answers
SOURCE: HP LaserJet 4345mfp won't scan, but it wil fax.
This may be related to 3 problems . 1st as with all 49.xxx errors update your firmware first. 2nd it may be related to a memory problem internal to the printer. Last it may be a problem with the email server you are sending to. To troubleshoot update firmware, then remove network cable and try to scan docs is as if you were going to email. If problem does not show check email gate way. If problem does shw up replacing your memory may be the next step.
Posted on Nov 11, 2009
ChadChadChad
First I would mention firmware updates can not be undone, I am using firmware from 2009, due to the fact the 49.FF09 error would happen hourly with the latest firmware. The odd part is March 2013 HP had a new firmware, which disappeared before I could use it. I believe they are well aware of this problem and just won't pony up to it.
Posted on Apr 30, 2013
Error code FF09
User's manual should be a PDF included in your software install CD. You will probably want to access that next time.
Apr 27, 2015 | HP LaserJet M3027x MFP Printer
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Our printer keeps showing service error FF09. What do I need to do to correct this?
In most cases the printerdriver software can have errors while being in use or is shut down. So to resetremove your printer from the PC and uninstall the printer software. Nowreinstall the printer software and then connect the Printer to be detected as anew hardware as it will be installed. Now check the printer properties to seethe ink levels.
Jun 16, 2011 | Computers & Internet
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
Service Error
The 49 series errors are firmware errors, you may need a new formatter pcb.
Nov 18, 2009 | HP LaserJet 5500DTN Printer
HP LaserJet 4345mfp won't scan, but it wil fax. Error code "49.FF09 Service Error" keeps coming up
Ensure that you have the error message correctly written down, then go to the HP Web Site and ask them about this error, specifically in conjunction with that specific printer or all-in-one device. HP can help you find out why you are having problems.
Nov 07, 2009 | HP LaserJet 4345mfp Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
Go to http: www.hp.com/support/
lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click
Download Drivers and Software.
Check for the latest firmware image
version at the bottom of the page. If
this firmware image is newer than the
one installed on the printer and the
printer can receive a firmware update,
download the newer firmware
upgrade.
if this fix does not work try removing memory from machine turn machine on see if issue perssist turn machine off replace memory one piece at a time (if you have more than one installed) testing printer each time if you put in one stick and it works then you put in the second and it doesnt the second stick would be the problem piece.. but usually on this machine upgrading the firmware will solve this issue.
Aug 08, 2008 | HP LaserJet 2430n Printer
try as techbybucky says. if no joy, try this LINK.
Feb 04, 2008 | HP LaserJet 2430dtn Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
820 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
